Brake dust problem no more!
http://www.armorall.com/products/vie...ry_index=wheel
It beads HONEY.
Here is an independent test I also found on the product
http://vimeo.com/10218627
more proof that detailers approve of this product.
keep in mind these are the guys who wash and clean their cars with tiny paint brushes and q-tips
I am assuming you are going to give it a try and I would be really interested in hearing what you think about it just after application and then in a few weeks, etc.
Ceramic pads would be great, but they don't bite as good as these stock pads IMO and the cost would be a lot more than general wheel maintenance.
My only concern is when you apply this to your wheel, does the wheel have to be off the car? If not, how will this product affect your brakes? There is bound to be overspray onto the caliper and disc and they have weird instructions for applying tire shine (apply tire shine before spray, then wipe off tire shine?).
vids look amazing, but doesn't show Brake Dust testing...wonder if it works
I guess I could waste several bucks for the test, but I heard Armor All products kinda suck tho no?
BTW I have an 03 Z with powerlab kit, full body kit and so on...
I've tried regular wax as well as wheel wax before, it prevents brake dust from really getting caked on for maybe a day. Does help when I want to clean them off though as I don't need to scrub as much, but it's still a nuisance and doesn't prevent dust from caking up on my wheels.
I really want to try this product. But unfortunately, today i went to all the places that carry Armorall products and they don't bring in this protectant yet, or may be NEVER.
I know Armor All has had a bad reputation for deteriorating plastics, leather and rubber, but this specific product is used on alloy wheels which is not absorbant -- I am just curious on what it does to the tires over time from the overspray.
On a side note, I was never a fan of Armor All Products, they turned my old car's tires brown with the tire shire and didn't hold the wet-look for too long.
The best tire shine is Michelin. If its available go out an buy it. I don't know if its because I have a Michelin tire or what. But the tire stays black and never turns brown, wet-shine lasts about a week!
They have a 3-step procedure:
Step 1: Michelin Wheel & Tire Cleaner
Step 2: Michelin 3 in 1 Tire Shine
Step 3: Michelin Brake Dust Repellent
My wheels have a matte finish and it didn't affect my finish at all. Still looks the same.
As for tire shine, I swear by Pinnacle Black Onyx Tire Gel. Lasts the longest of the many products I've tried and only requires one coat to get it nice and glossy. Also smells like gummy bears! As for wheel cleaner, P21S Gel Wheel Cleaner. My wheels look brand spanking new every time. Still having a hard time finding the right wax/brake dust repellant. Might have to give that Michelin stuff a try! I have Poorboy's wheel wax that I put on regularly, it helps, but doesn't eliminate the problem.
aowhaus, just saw your question about the tires, I applied tire shine prior to using this wheel protectant and it didn't have any effect on my tires. I could see where the runoff was from my wheel to the tire to the ground though, but nothing a little touch up from my tire shine didn't fix (still glossy, but you could tell something else was on it!). I don't think it will have any adverse effects on tires if you use tire shine to protect your tires. However, I was skeptical about its effects on the brakes, so I ended up covering my brakes with paper towel. One section opened up when I was spraying due to wind. You could tell where the product made contact with the brake disc, but it was removed when I pulled her into the garage after application. Either way, I just don't trust this stuff being sprayed directly onto the brake disc or caliper.
I find that if the wheels were not completely dry when I applied or gets wet while the spray is drying I get those white water spots.
