Battery jumpstart and radio? audio?
Old Apr 17, 2010 | 01:29 PM
mercedesintexas's Avatar
C300(w204)
I just did battery restart done by MB customer service.
I tried to turn on a radio and it didn't work.
How can I restart my audio system?(6cd changer)
Thanks,
Old Apr 17, 2010 | 02:35 PM
clover168's Avatar
c300
bring it back to MB and ask them to fix it since they did the jump start.
Old Apr 17, 2010 | 02:52 PM
C300(w204)
Thanks, it's the weekend, so they aren't open today.
Is there any way I can do by myself?
I read some in the internet, they have to put some code according to my VIN#. Is that what needs to be done?
Thanks,
Old Apr 17, 2010 | 03:21 PM
Diesel Benz's Avatar
Thanks,
A 204 should not have any code. Do you mean the head unit does not turn on? How would you enter the code then? If it turns on and asks for a code, that would be new to me (later head units have a code but that should be needed only if the device was moved to another car).
Did you check all fuses, perhaps some have gone from the jump-start.
Old Apr 17, 2010 | 05:30 PM
f4i 954's Avatar
2009 e class 2012 ml350
Thanks,
If the radio wont even turn on, the fuse in the back of the radio got fried (mini fuse)
Old Apr 17, 2010 | 06:40 PM
C300(w204)
you mean under the hood? or behid the dashboard? I hope it's under the hood. If it's out, can I get it a place like an AutoZone?
Old Apr 17, 2010 | 06:41 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
I remember disconecting my battery for like an hr or so and didnt require any type of code for the radio. Everything just boosted right back up, even my radio setting were still the same.
Old Apr 17, 2010 | 06:48 PM
C300(w204)
Both positive and negative?
What I heard from a service man saing was to remove both from the battery and touch each other for 3 seconds.
please share your experiences.
Thanks,
Old Apr 17, 2010 | 07:11 PM
C300(w204)
Okay, I just went down to do both plugs off from the battery.
I tried to make both plugs each other for over 3 seconds and reconnected them, but doesn't work.
Is there an order when you put both plugs back to the battery? positve first?
Old Apr 17, 2010 | 07:21 PM
f4i 954's Avatar
disconnecting, negative first.
reconnecting positive first.
Old Apr 17, 2010 | 08:59 PM
C300(w204)
fuse box for audio
I think my fuse for audio system is out and I want to change the fuse for the audio. Where can I find the fuse?
I opened the hood but no picture. Is it inside the fuse box in the driver's seat?
I looked into the manual book. It doesn't have a picture.
Thanks,
Old Apr 17, 2010 | 09:22 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Threads merged. Still same audio subject. No need for a new thread.
Old Apr 18, 2010 | 01:40 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
A leaflet of the details of Fuses are usually in the spare tyre gear in the boot.
