Base Stereo w/MM in 2010
) and the results were mixed. Can anyone with a 2010 comment on their base system now that that system will probably be in 90% of all C Classes? (my dealer had 126 in stock and few if any had the H/K option checked).I have a 2009 BMW 135i and I have to say the base system is more than adequate for what I am looking for. It has a sub under each seat and plenty of power.....I have no regrets about not getting the upgraded sound in the Bimmer. I'm hoping I feel the same way in the M-B. Are there factory subs with the base system? All I could find was that it has 8 speakers.
The HK upgraded sound system is really quite good... obviously better than the base system. That being said, the base system isn't bad, and many people like it just fine. I've heard both as almost all loaner vehicles I use have the base stereo and I'm never that impressed by it - however...
I'm a bit more of an audiophile, so the HK system for me was a must - Also, that being said, for the additional cost for the HK system, I've heard better - you aren't exactly getting your money's worth on it and might be even better upgrading the stock yourself with new speakers and amps to get amazing sound for the cost of the HK "good" sound...
- Eric
The HK system sounds great (at least it did in the 09 C350 I test drove), but it's tough to find a car equipped with it since MB decided to make it a stand alone option for 2010.
Audio is always easy to upgrade (and you can upgrade it for less $ than the cost of the actual HK system) so don't get down on yourself if you can't find a car equipped with the HK sound system.
So if you are located in a market like LA, SF, NYC or Mia(where I see many dealers with the above cars with MM and HK options lightly equipped) it might be worth your time to call a couple of other dealers and see if the have the car you want in stock or are willing to dealer trade for it.
I hope the above info was helpful.
I'm glad to hear the good feedback about the base system, just a bit bummed that there's no factory sub. Again, I'm perfectly pleased with the base system in my Bimmer so I hope to feel the same when I pick up the Benz. Worst case, I can always add a sub like lewylou78 did.
The factory subwoofer in the HK system in located in the rear shelf behind the rear seat top section. My bazooka is located almost in the same place, but a couple feet lower. Subwoofers in cars should be located towards the rear in my opinion. I like how Mercedes placed most of the speakers up front (surrounding the driver and passenger), but the base system would have sounded much better if they added one measly subwoofer in the rear shelf. Instead, they don't add any subwoofer on the base system and only give you the option of buying the HK system for over $800 (which isn't even installed on that many c-class cars to begin with).
I had the BOSE studio on wheels in my Infiniti in the premium package, and that system was amazing.
The stock system is more than good enough for me coming from the upgraded system in the infiniti. My butt shakes when the volume is cranked. While the stock base system does not perform as well with highs or lows compared to my BOSE. You would never know your missing anything if I never had it. Sounds great and would put the extra money towards Lamin-X, X-pipe, tints, or front/rear spoilers or lips/ diffusers. That's just my opinion.
What I recommend: Go to the dealership and ask to see a base sound system C class, and one with the HK system. Of course one will sound better than the other, but is the base system suitable for your needs? Just crank it up, my dealer let me. I decided the base system was ample, with the option to upgrade it down the road with the money saved.
