Sylvania H7SU vs. HID
I'm considering the DDM Kit but was wonder if I could get a much bright look from the halogen with the upgrade bulb replacement. Seems this would be a super easy upgrade if it is that much brighter.
Also, our high beams use the same bulb as the low beams, correct?
I'll have to order new low beam caps before I buy another pair for my low beams.
There's a whole thread by Vic_Viper about them, but I think there's 2 kinds.
Philips CrystalVision 4000k and 4300k. The ones at O'Reilly are the 4000k.
I hope there's no difference between the two.
I've also heard Sylvania Silverstar Ultras still have a slight yellow tint to them, which is not what I want.
They are also like $10 more expensive a pair.
I had one side in with the OEM halogen and the other side with the H7SU. I could not tell a difference between the two in brightness or color. Had my beams point at a wall, drove with them, no difference. Bummer, sounds like the Philips CV is a better bulb.
Incidentally, I replaced the light on the passenger side and it was VERY easy, maybe too easy. There was one step I didn't do. I was trying to pull the plug off the pins of the bulb and the lightbulb snapped out of the housing, no pressing on the metal clip. I then pulled the light out of the plug. Is this a new design in the 2010? Putting it back in, I replaced the light into the plug and then pushed the light/plug into the housing and it snapped in nice and snug, again, no fiddling with a clip. Is this correct?
So of course both low beams looked identical. In my defense, I was doing this at night with a flash light.
I will retry the experiment again later. I expect to see SOME difference between the OEM and the Sylvania SilverStar Ultra. If not, I will try the Philips CV although I was reading a thread on the Luminics Krypton series that makes them sound very interesting!
So I will try something else. What's the consensus here, MTEC Super White, MTEC Cosmos Blue, Philips CV, Luminics Krypton, or ??
I'm concerned because in many of the pictures I've seen, they blueish halogens that looked more like HIDs were horribly low on light output.
Also, I may order a 4.5" LED strip I saw from a vendor on here. I measured and it looks like it will fit nicely next to the fog light near the top of the mesh. I would want to wire it for always on. Any suggestions on where to tap into?
let us know how the Luminics bulbs work out, I'm interested in upgrading as well.
I'm hoping the Luminics bulbs are good. It was either those or the Philips CV or DV. Should have the Luminics by Wed or Thur next week. I'll post a review and hopefully some pics.
Which LEDs did you order?
Saw it, I believe he is comparing these bulbs in the fogs, not the low beams. I did see pics of some of these bulbs in the low beams but everyone's camera is different, so if someone can post another pic, it would be great.
Because of the shiny interior of the assembly, the entire interior glows with the color. And the lens of the low beam, non-xenon changes the color a bit also. It really needs a pic with the correct exposure to get a good idea how it would look.
