New Brakes - are these junk?
I would like to change them all at once, has anyone here tried out this set of pads/rotors from eagle brakes?
http://cgi.ebay.com/ebaymotors/MERCE...Q5fAccessories
I havent looked at the front rotors/pads yet.. might put it up on the lift after work though and pull the stuff off.
Cheapest option: akebono ceramic pads w/ resurfaced rotors @ ~120
Next: Akebono ceramic pads with new ebay rear rotors @ 250
or: Eagle brakes full F/R set @ 350
or: something else..
why do your rotors need resurfacing...did you follow the maintenance schedule?
Update, just decided to buy some akebono pads for the rear. Now I just need to decide on what to do about the rotors
its embarassing
Be careful about off-brand components because if they are Chinese, they are likely inferior. I don't see any info on the website about country of origin.
Weber Bros Auto USA-PA(Lebanon) 1-800-222-2528
from car-part.com
I would go this route before any aftermarket unless the aftermarket is TUV approved
Whats the point of having hard pads that cause undue wear to your rotors or vise versa.
Pads are cheaper than rotors.
I have heard on this forum that one should achieve 2 pad replacements before the rotor thickness is under limits.
Choosing the correct rotor / pad match requires expert knowledge .
If you use OEM you will be within specifications.
Akebono can be used with any rotor.There is no pad matching to rotors.Unless you are running ceramic rotors which you are not.
So no expert is required.If akebono be sure to properly bed them in per instructions.
www.tirerack.com carries them.
You most certainly do not want to use drilled rotors. They crack
Rears were 10mm original . Minimum allowed 8.3 mm.
1mm equals 40 thousands of an inch.
If say, after 50,000 to 100,000 km your wear is 1.5 mm , this leaves very little room for machining anyway.
I still say if fitting new pads make sure that they are not going to adversely affect your rotors & will give adequate performance.
Surely some research on there compatibility is required.
