W204's and offsets of wheels
Old Jan 19, 2012 | 11:35 AM
  #326
Matt_Eurojerks's Avatar
w204 C300
Originally Posted by sjbtax
Looking at ordering Works VSXX Chrome for 2010 W204 C200 CGI
Front: 18 x 8.5 with 235 tyre
Rear: 18 x 9.5 with 255 tyre
What would be the optimum offset required?
I think mid to low 40's
Old Jan 20, 2012 | 10:46 PM
  #327
Stevedotmil's Avatar
W204 2010 C300 Sport/6M
Originally Posted by Matt_Eurojerks
Kleemann MS-11's 19x8.5 et35 19x10 et55 245/35 and 275/30's with H&R springs:
Does anyone know if the C63 has wider front fenders than the regular C because these are the specs for the wheels I want and I want to make sure that they will be fine. Everyone keeps saying that the 19x8.5 +35 will NOT work for the W204 but apparently it does according to this guys car if the info is correct and the fenders are the same width.
I used the calculator on 1010.tires and it says that going from 7.5W +47 offset stock to 8.5W +35 offset will be 1mm closer to the strut and 25mm out towards the outer edge of the fender. .95 inches. The rears are money but the fronts are what I'm worried about. Does anyone know who's car this is? I'm going to be running 235/35/19 in the front too. Thanks.
Old Jan 20, 2012 | 11:13 PM
  #328
eliteskill's Avatar
W204 09' C350
18x8 +30 all around.. lowered on H&R sports.
Willing to roll fenders. Will it fit?
Old Jan 22, 2012 | 07:19 PM
  #329
Pretty sure that 30 isn't going to fit. It's going to stick out more than a 1/2 inch past the fender in the front and enough to look rediculous in the rear especially lowered. Unless you are going for that look. If you are past the fender there's no point in rolling anything. There isn't much to roll there anyway. Most people trim.
Old Jan 22, 2012 | 09:36 PM
  #330
eliteskill's Avatar
W204 09' C350
^ thanks for the help... offsets on our cars are so weak.. its very disappointing looking for rims that fit.
Old Jan 22, 2012 | 09:40 PM
  #331
NP. I know because I have been searching for wheels for some time. When I get time tomorrow I'm going to go through the hassle of figuring out what the hub to fender measurement is so it's easier to calculate how flush or poke certain rims are. I'm tired of guessing.
Old Jan 23, 2012 | 02:32 PM
  #332
mikedaman's Avatar
2006 CLK500
c300 with 20x9 fr and 20x10.5 rear with h&R sport
this is the rear lip 7.5"
Old Jan 23, 2012 | 02:56 PM
  #333
Frnakito71's Avatar
C300, 93tt RX7, 88RX7 Vet, 83RX7
What did you do to make that fit?
Old Jan 23, 2012 | 04:30 PM
  #334
ex4Rings's Avatar
2009 C350, 2012 ML350
Thoughts?
I am looking into the Petrol Fausts in 19", they only offer 2 sets of offsets and I am not sure if both will work:
Option 1 -
19 x 8.5 ET 32
19 x 9.5 ET 35
Option 2 -
19 x 8.5 ET 42
19 x 9.5 ET 52
I can save $400 going with Option 1 but I am not so sure it would work, I don't want to rub and I am lowered with H&R Super Sports.
I am almost 100% Option 2 will work but was concerned the offset difference between the front and back might not look right, plus I would think 52 in the rear would not line up well with the fenders. I like a flush stance, if not even a little wide. I guess I could go option 2 and use a slight spacer in the rear.
Here is what I am looking at:
http://www.ebay.com/itm/370550833807...84.m1423.l2649
Old Jan 23, 2012 | 05:37 PM
  #335
Mikedaman........your post would be 1000% more helpful to everyone if you posted the offsets for your set up front and rear. That is the single most important bit of information given our cars have such high offsets. Anything lower than +35-+40 in the front is pushing it and it seems like you are pretty close to that. I like your set up by the way. Those lips are nice. I like your exhaust outlets. Are those just for looks or are they welded to the mufflers if you have any?
Old Jan 23, 2012 | 06:03 PM
  #336
w204 C300
Did you get a better idea?
Old Jan 23, 2012 | 07:02 PM
  #337
mikedaman's Avatar
2006 CLK500
the offset front is 45 and the rear is 52, i got my wheels custom fitted original offset was 35 front and 40 rear.. my suggestion is just get the wheels you really like and find local custom wheel shop that can drill holes or shave the back of the hub to make it work... i know the w204 have a high offset to begin with.
the exhaust do work..
Old Jan 23, 2012 | 08:56 PM
  #338
I measured and the stock hub to outer fender edge is 2.75" or 69.85mm (70mm). Then if you want to split hairs even more the fender lip is .25 or so which is 6.35mm so just to be on the safe side in order to clear the inner portion of the fender for the fronts you would need to use 63mm as the hub to fender measurement to tuck with no problems.
So what was your final offset for the front after you modified your wheels by shaving (?mm) off the mounting surface?
http://www.jonathanrowny.com/page/offset-calculator
Use this calculator to figure it out and then let me know how close it is to what you actually see on your car. Did you trim your front fenders?
Old Jan 23, 2012 | 09:29 PM
  #339
tasho3's Avatar
2014 C63 Sedan
Would this wheels fit my 2008 C300 4matic
18x8.5 ET 45 front
18x9.5 ET 45 Rear
Here is a link for wheels I'm looking to put on:
http://www.ebay.com/itm/18-SPORT-GRE...#ht_3823wt_814
Old Jan 23, 2012 | 10:46 PM
  #340
Those would definitely be fine as far as working well.
Old Jan 24, 2012 | 08:07 AM
  #341
ex4Rings's Avatar
Originally Posted by ex4Rings
Thoughts?
Option 1 -
19 x 8.5 ET 32
19 x 9.5 ET 35
Option 2 -
19 x 8.5 ET 42
19 x 9.5 ET 52
Anyone?
Old Jan 24, 2012 | 09:12 AM
  #342
Option 2
Old Jan 24, 2012 | 10:14 AM
  #343
w204 C300
Anyone?
Option 2 will be care free. Option 1 will rub with someone in your back seat if you dont strecth the tire.
Old Jan 24, 2012 | 10:25 AM
  #344
ex4Rings's Avatar
Awesome thanks guys, do you think running 42 in the front and 52 in the rear will look good, just seems the offsets are pretty far apart.
Should I put maybe a 5mm spacer in the rear or just leave it. I want a flush look with the fenders, maybe even a wide stance.
Old Jan 24, 2012 | 11:45 AM
  #345
Stock offset for the C63 rims are +42F and +54R and they should sit pretty flush on a regular C Class. That's what I decided to get instead of getting low offsets and messing with it. I might get some spacers but I'm going to wait and see how they look.
Old Jan 24, 2012 | 01:28 PM
  #346
ex4Rings's Avatar
Excellent! Would love to see some pics once you get them on.
Old Jan 24, 2012 | 08:46 PM
  #347
I can barely contain my enthusiasm since I have waiting for almost a year to get wheels and tires.
Old Jan 25, 2012 | 12:57 PM
  #348
lfilomeno's Avatar
C300 Sport
is this a C63 or a C63 body kit? Looks geat either way!
Old Jan 25, 2012 | 02:16 PM
  #349
itsLoonie's Avatar
2012 E350 RWD
It is an actual C63 AMG.
Old Jan 27, 2012 | 02:09 PM
  #350
JVEE120's Avatar
2009 C300 Sport manual
Checking to ensure no tire rub
Looking at this setup....any experience out there? I've been reading throug TONS of forums.....here's the setup
2009 C300 Sport
Mandrus Manheim
19x8.5 +43 offset
19x9.5 +53 offset
looking at going with H&R Super Sports and 235/35ZR19 fronts and 275/30ZR19 in rear....am I gonna have problems with the rears scrubbing even with the high offset?
Appreciate the responses
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
