W204's and offsets of wheels
Find some wheels u like or u have and post the specs or what u r trying to do. running for example 40/44 is almost no difference than 42/48, the majority here would never know it was different. Ur talking a 16th up front and an 1/8" out back difference, kinda get it? Once you are on coils or supersports ur car will look so much better to you and fit better with aftermarket wheels. The offset isnt as big a deal to the overall look like stock ride height cars. If you carry full loads and passengers alot I would rethink springs like SS. they are kinda bouncy, u lose that MB ride a little, more Bimmerish. Coils are the way to go, almost no difference and some brands ride better than stock.
I guess the look I'm looking for is a flush look, maybe a minimal tuck or half finger gap, but no poke or excessive stretch.... Sorry again Jimmy. I guess I'll just have keep gathering info. You've been very helpful tho. Eventually I'll gather enough info to know the what the limits are vs A and B or even C setups.
And pony euro63s will clear any setup, I have my set on now. U can clear the lowest of setups w 42/48 they are good budget wheels if your gonna invest in high ends too. I ride my brabus VIs or Carlssons for shows
Considering it is for my wife's car and her specification is to lose as little ride quality as possible it sounds like a little extra tyre and the flat sidewall may be the way to go.
Your help is much appreciated.... As always.
Looking at Falken Ziex ze-912, probably either 215 40 R18 or 225 40 R18. I haven't made any other adjustments and would preferably have the same size on all tires.
either size is fine, depends on how fat u wanna go w tires. If your more concerned about having nice wheels and dont mind a little tire go 225, thats a factory style fat straight sidewall. If you want a little less fatness almost straight go 215. Even a 205 would barely be stretching the tire, stock Cs w 18" AMGs have 8 + 8.5 factory w 225/4018 and 245/35/18 staggered setups so you have an idea if you wanna look at stock photos and get an idea how the tire beef is.
I'm on stock suspension and won't be lowering. What are your thoughts on these for a c350? My tire guy wants to go fat on the back with 275's (per below) but I'm skeptical and was thinking 265 as I want a wide and aggressive look but flush
rims (rear) 19" x 9.5" (5-112) +45
1 HR73-6656-4 Centering Rings (Set of 4) 73mm-66.56mm
2 CG CG ContiExtremeContact DWS 91Y 235/35ZR19 XL
http://www.velocitymotoring.com/wheels_v718.html
I'm not so sure what offset would be most suitable
18 x 8.5, 5x112, 35, 66.6 would that work all around on my c300?
I would stay away from 20s if it was me. The rears on 20s need to be 25 series 95% of the time and they are 300+ per tire. 19s are under 200 tops, and 20s dont look good unless you do it right. Theres 2-3 guys that have proper 20s on this w204 section its not easy to do. Look at hotelcrazy's thread for some proper 20s..........
