W204's and offsets of wheels
Old Apr 19, 2012 | 11:48 PM
  #526
mhad2480's Avatar
2011 C300 Sport, 2007 Nissan Titan Crew Cab
Originally Posted by jimmythegreek
you can go much more than that, I have two sets that I did 5mm on one and 8mm on the other. We are talking wheel hubs here, NOT the cars hubs, not sure people reading this know what I/we mean here. Most wheels are almost identical, they are just cast/forged w a thinner hub/boltup thickness to adjust for offset. Think about forged wheels, its the same wheel but they can make any offset you want, HOW? They adjust the cast and machine the wheels. U can simply call around and find a highend or good machine shop that does CNC routing. They will mont the rim and buzz off whatever u need and or what they think is safe. My BRABUS wheels were 30 out back and 35 out front, I did 5mm fronts and 8mm rears and I could have went more out back they are thick as hell..........
I was thinking they could probably take off more, but I'll see what the shop says. There is a lot of meat on the center hub on the inside. I went w/ a 275 rear with the Hankook V12's. I kinda wish I went w/ a 265, but I had read that the Kooks run a little narrow. Oh well. Now I just have to get under there and see how much room I have so I don't start rubbing on the inside.
Old Apr 20, 2012 | 12:00 AM
  #527
pnoyworx's Avatar
10 E63, Sold -07 E63
I guess each shop have different ideas of safety. When I had the Iforged's the guy would not allow me to remove too much due to safety issues. But also at 30+ et's the hub would be thicker than a 45et. I am not sure what the thickness would be sufficient to handle curb weight and the standing weight of our cars.
Old Apr 20, 2012 | 01:46 PM
  #528
Cycosis's Avatar
2008 C230
So where did people buy their H&R super sports?
Old Apr 20, 2012 | 01:52 PM
  #529
C300Man's Avatar
C300
Fle-ebay sells them for $280.00
Old Apr 21, 2012 | 01:42 PM
  #530
almac04's Avatar
C350
So I just picked up some 20's on c-list, I don't think I like them as much as I thought I did. They are not staggered and I believe they should be. 20"x 7.5 all the way around. I got them fir a deal but I'm more than likely going to sell them before the end of the summer or spring!
As listed:
On my car:
Old Apr 23, 2012 | 02:29 AM
  #531
cunha1679's Avatar
2008 C300 4matic
Something about that red made those wheels pop, but they still look real nice on your ride. some MB center caps & spacers to push em out a little would complete the look.
Old Apr 23, 2012 | 09:58 AM
  #532
almac04's Avatar
C350
Well I already ordered the center caps, as far as the spacers go, since the wheels are so skinny I'm gonna leave'em like that and perhaps replace the wheels in back with a wider pair, that is if I even keep these. Most def it was the red that makes those wheels "jump". Got the entire set plus wheels for $900, can't beat that though.
Old Apr 24, 2012 | 02:28 AM
  #533
juice619's Avatar
2018 GLE AMG 63
c300 wheel fit from e350
can some one with experience pls explain if this set up will work on my 2010 c300 sports
the link shows the wheels i want to put on
thnx
http://www.socalwheels.com/view-prod...Silver#gallery
Old Apr 25, 2012 | 04:11 PM
  #534
mhad2480's Avatar
Well, I went by America's tire today to see if they can get my TPMS working, they didn't, but I told the sales guy there that my rear passenger tire is rubbing and was thinking I should have gone with a 265 instead of the 275 and he said I can return them and get the 265s and they would pro-rate it based on mileage. I'm gonna try that & since I have put minimal mileage on the tires I should get almost full credit towards the 265s and since they would be cheaper anyway it should almost be a wash. I was kinda skeptical about messing with the integrity of the rim. What I don't get is why is one side rubbing and the other not? Could going from 17s to 19s throw of the cast/camber? I wouldn't think so since the overall diameter is almost the same, but I don't know for sure. Any one have any input on this?
Old Apr 26, 2012 | 08:03 PM
  #535
okay.w0w's Avatar
none
would these fit?
Fronts
19x8 5x112 +32mm 245/35/19
Rears
19x10 5x112 +45mm 285/30/19
Old Apr 27, 2012 | 12:16 AM
  #536
mangoango's Avatar
08 C350
Originally Posted by okay.w0w
would these fit?
Fronts
Rears
They might work with different tire sizes. 235/35 front, 255/30 rear?
Check out this thread. His wheel specs are very close to your wheel specs.
Old Apr 27, 2012 | 01:49 AM
  #537
pnoyworx's Avatar
I'm thinking this would be a very very tight fit. The ET upfront is too aggressive with those tires.. you may get away with 225's, or 215's but the 215's are not weight specific to our cars. The rear's ET is also aggressive but you may be able to squeeze in 265's stretched. With your current specs you will rub in all corners even on stock height. If you like the POKE look (pass the fenders) then this setup will give you that. You may want to double check with JimmytheGreek. He's the guru...
would these fit?
Fronts
Rears
Old Apr 28, 2012 | 01:47 AM
  #538
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
would these fit?
Fronts
Rears
Be the first to make it work
But I tell you right now it won't be easy.
You have to shave or roll (preferably roll) your rear fenders. Heat gun any tire friction points on your fender liner. With a 45 offset you have to run stretched tires... like a 255/30.
You also have to shave or roll your front fenders. If you want to stick with wide tires and don't want the stretched look the only solution is too pull your fenders and repaint them if you don't want damaging it especially if you decide to go lower.
Old May 6, 2012 | 07:35 AM
  #539
hwpaints's Avatar
c180 coupe
will this fit with out rubbing, on a C coupe 204
rear 245/30/20 et 40 or shaved 45 10j wheel 20 inch
front 225/30/20 et 35 or shaved 40 8.5 wheel 20 inch
my wife is killing me when it rubs, i try now 245/30/20 et35 in front en rubs back 275/30/20 et40 rubs also
is it enough whit 245 in the back and 225 in the front they can shave 5mm of the wheel
thanks for answer
Old May 6, 2012 | 12:19 PM
  #540
jasong93's Avatar
2000 e320
Thumbs up
Originally Posted by itsLoonie
Took some pictures before I put my stockies back on. Gonna unreverse mount the front and just leave the rears as I said. Shaving the rear fenders then getting some 3mm spacers for the back possibly and 5m for the front.
So final specs will possibly be something like:
9 +40 (45 before spacers)
10 +32 (35 before spacers)
Here are the pictures:
FRONT
REAR
i think you should do a video shoot of this setup...its pure beauty simple and clean your car is the reason why i want a c300 would really like to see updates of this and if you can do a video shoot it would show how you car reaaly sits on those bbs..moar pics and updates !
Old May 6, 2012 | 02:28 PM
  #541
okay.w0w's Avatar
none
bbs lms are some of the sickest wheels out
Old May 9, 2012 | 11:25 AM
  #542
hwpaints's Avatar
c180 coupe
thanks for answer
nobody can help me
Old May 9, 2012 | 11:44 AM
  #543
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
thanks for answer
are you lowered or stock height? If stock height you need
225/30/20 up front w +35
255/25/20 out back w +40
you cannot clear w 30 profile out back w a 40 offset. maybe w 45 offset. u must use a skinny brand tire either way. 20's are no good for w204s too much a pain w tires and $$$
Old May 9, 2012 | 11:46 AM
  #544
would these fit?
Fronts
Rears
215/35/19 up front
275/30/19 out back
stock height only. lowered u will not clear up front no matter what unless u stretch and poke. out back u can make it lowered w a 255/30/19 w a +45mm offset
Old May 9, 2012 | 12:20 PM
  #545
hwpaints's Avatar
c180 coupe
Thx for answer Jimmy,
it's stock height and the wheels are old from other car,
i have 245/30/20 i plannend for the back and buy new one's in front 225/30/20 but it is stretched in the back, I think I can live with that but not with rubbing, I can let shaved the wheels to +45 for 10x20 and +40 for 8,5 x20
they looks good under the car, i was hoping there are more whit this offsett
By hwpaints at 2012-05-09
Old May 9, 2012 | 04:11 PM
  #546
pnoyworx's Avatar
Jimmy's alive.. haven't seen you around for a bit.
Old May 9, 2012 | 04:30 PM
  #547
itsLoonie's Avatar
2012 E350 RWD
He's probably working on something big. Or just been busy. Maybe even both.
Old May 12, 2012 | 05:09 PM
  #548
IW IE IS IT IA's Avatar
2012 C Class
Question? Im new to the forums and I just purchased a 2012 C Class Sprt I'm looking to get the BBS LM 19's with H&R lowering spring will you please help me out on the off set and tires size so I wouldn't have to roll my fenders and have no rubbing.... Thank you
Old May 13, 2012 | 09:43 PM
  #549
Cleanbenz's Avatar
2010 E350
Posted pics in other threads but here's mine again
VMR V705's 19x8.5 ET +45 215/35-19 and 19x9.5 ET +45 235/35-19
Old May 13, 2012 | 11:53 PM
  #550
2012 C Class
What kinda of springs you running and are your fenders rolled and does it rub?
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
