W204's and offsets of wheels
Old May 6, 2015 | 11:46 AM
  #1451
dudeitsmattx's Avatar
2013 C250 Sport
Originally Posted by MyManDan26
I want to have my factory set of wheels ready to go so when winter comes around I can just pop them back on. In that case would probably just be smarter to buy 4 new ones.
Check out oewheelsllc.com they have the best prices on TPMS I could find. This is where I get mine from as do others on this forum.
Old May 9, 2015 | 06:45 AM
  #1452
Havardekul's Avatar
W204
Will these rims fit, and what tire specs do you recommend?
Car is on stock sports suspension.
(W204 C220CDI)
WIDTH: 9" Front / 10" Rear
OFFSET: et42 front / et45 rear
Or
9x19 ET42 all around
Old May 10, 2015 | 08:05 PM
  #1453
w204dant's Avatar
2010 c300 4matic sport
It will be close I'm running 18x8.5 et42 and 18x9.5 et38 in the front I have plenty of room I could have ran a 18x9 and my rear is about 1mm away from rubbing when I tuck tire lol (255/35/18) is my rear tire hope that info helps
(W204 C220CDI)
Or
Old May 10, 2015 | 08:24 PM
  #1454
2013 C250 Sport
(W204 C220CDI)
Or
Going 10" wide in the rear I would not go over et47 but 2mm should not make much of a difference. If you plan to lower you will encounter rubbing issues.
Old May 13, 2015 | 02:49 PM
  #1455
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Thumbs up
I love the wheels; what are they? Also, because it would be my wife's daily driver, what offset would I use if I was to go a 1/2 inch smaller for the front and rear to keep the from being scratched? Would be able to keep the same tire sizes?
Originally Posted by aknedude
here is mine.
rear 9,5x19 ET 45 with 255/30 front 8,5x19 225/35 ET45 lowered on H&R SS
NO rubbing with 4 growups in the car.
Old May 13, 2015 | 02:51 PM
  #1456
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
looks sharp
Old May 13, 2015 | 02:55 PM
  #1457
MB Marko's Avatar
Ya I'm defiantly going 18's I need something thats great quality as well as keeping my ride feel nice also i looked at 3piece rims i didn't find one style that i liked. AMG rims are nice but everyone has them I havens seen many C class with the Mandrus Rotec rims and the ones Ive seen online look amazing also its usually the c63 they throw it on online.
Old May 13, 2015 | 03:16 PM
  #1458
2013 C250 Sport
*Chatmanr - Going 1/2' smaller width won't help much in terms of curb rash. Just teach her how to drive right lol..
*Newmbmarko - Have you looked at the the companies that see 3 piece wheels? There are at least 30 different companies and all have tons of different styles and designs.
Old May 13, 2015 | 03:34 PM
  #1459
MB Marko's Avatar
yes i have i have been looking for a month now every night for 2 hours plus I'm sick of looking hahaha i feel like a girl looking for a wedding dress
Old May 13, 2015 | 05:49 PM
  #1460
2013 C250 Sport
Haha I feel you!! I was the same way! Spend so much time looking for wheels and the right offsets. I found lots of wheels I like but the offsets were always wrong. So that's why I went custom 3 piece
Old May 14, 2015 | 02:14 PM
  #1461
aknedude's Avatar
mercedes w204 c350
They are ISPIRI ISR 10 Wheels
http://www.ispiriwheels.com/ispiri-isr10.html
Old May 14, 2015 | 03:02 PM
  #1462
Becksan's Avatar
2018 E43
You can also get them as MRR GroundForce GF9 - they are marked with the Inspiri on the wheel.
Or mine are at least 😉
Old May 14, 2015 | 03:04 PM
  #1463
Becksan's Avatar
2018 E43
You should be good at those offsets. I got the GF9 in ET40 & ET42 which are flush with 235/265 tires.
Old May 15, 2015 | 02:43 PM
  #1464
MyManDan26's Avatar
C300
Will rims with a 35mm offset fit these tires?
225 35 19 Front
255 30 19 Rear
Apparently my rims are out of stock. I already bought the tires so I'm going to just buy the rims in gunmetal and have them chromed myself. I can only find them in 19x9.5 40mm offset and 19x8.5 35mm offset. The original ones I bought were 45mm
will these fit?
19x9.5 40mm
19x8.5 35mm
Old May 15, 2015 | 06:03 PM
  #1465
2013 C250 Sport
Yes they will all fit. Offset has nothing to do with tire size
Old May 17, 2015 | 02:13 PM
  #1466
Havardekul's Avatar
W204
Front 19 x 8.5" ET45.00
Rear 19 x 9.5" ET40.00
Will these work, and with what tires?
Stock sports suspension.
Old May 17, 2015 | 03:43 PM
  #1467
2013 C250 Sport
Yeah they will work. Go with 235/35/19 and 255/30/19
Old May 20, 2015 | 11:41 PM
  #1468
MyManDan26's Avatar
C300
Anyone have a pic of what 8.5 9.5 ET35mm all around looks like? After reading some posts on here I'm worried about the wheels rubbing. I read that there is only a credit card space of clearance.
Old May 21, 2015 | 12:33 AM
  #1469
MB Marko's Avatar
I tried to put 35et on and it was poking out front and back now I'm going with 45 front 54 rear
Old May 21, 2015 | 08:37 AM
  #1470
MyManDan26's Avatar
C300
I dont mind if they poke, I just dont want any rubbing.
Old May 21, 2015 | 11:04 AM
  #1471
2013 C250 Sport
My fronts are 19x8.5 ET 35 and lowered on coils and I don't have any rubbing up there. As for the rear I have 19x9.5 ET 40 and only the passenger rear rubs for some reason. with ET 35 it would rub a little more since it would be 5mm more poke.
Old May 21, 2015 | 02:23 PM
  #1472
MyManDan26's Avatar
C300
Probably going to send the set of rims I got back then. They're all 35mm offset, most AMG style rims I saw were 35mm.
Old May 30, 2015 | 10:58 PM
  #1473
ripratama's Avatar
C180 W202
Will these fit?
Hello folks,
Greetings from Jakarta, Indonesia. I recently acquired a Classic-trim C200 Kompressor and would like to upsize the wheels with either of these specs:
Front 18" x 8" ET35
Rear 18" x 9" ET35
Or
Front 18" x 8.5" ET35
Rear 18" x 9.5" ET35
Planned tyres are 225/40 and 255/35 fronts and rears respectively.
Will both specs clear the fenders? There may be 3 persons in the back on some occassions. Not planning to lower it; however may change the spring pads if the gap becomes too large.
Thanks for your help.
Old May 31, 2015 | 05:05 AM
  #1474
aknedude's Avatar
mercedes w204 c350
Originally Posted by ripratama
Hello folks,
Front 18" x 8" ET35
Rear 18" x 9" ET35
Or
9,5 ET 35 will rub like crazy and stick 10mm out from the fender, you need ET45 at least. 8,5 et 35 will stick 5mm out in front and rub. ET 40 is max in front with 8,5. go with ET 45 to be sure.
Old May 31, 2015 | 09:11 AM
  #1475
ripratama's Avatar
C180 W202
Thanks aknedude. Was looking at some old but nice sets of wheels like Carlsson RS and Brabus Monoblock IV. I guess I must look elsewhere. Kinda miss W202 and W203 with their tolerant setups.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
