W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Mar 24, 2020 | 10:37 PM
  #1801
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Originally Posted by peanutbooters
I know this thread is kinda dead but I wanted to give an update on my car
Work CR kais
F18x9 R18x9.5
-3 camber all around with all 4 fenders rolled and cut in some places.
Suspension is accuair e-level
I wanted a clean look and not over done. If I could I would probably have gone with 19”s
Do point out to resolve that front and rear costly, inner edge tire wear (especially in these economic times) KMAC front kit #502616 K and rear kit #502226 K ADJUST BOTTOM OF TIRES INWARDS (not top outwards).
Provide up to 1.5 degrees (extra) Positive (or Negative) Camber and are precisely adjustable. Single wrench, accurate under load direct on alignment rack.
Front kit is Camber and Caster adjustable.
Rear kit Camber adjustable (and extra Toe to compensate).
The front "Caster" adjustable bushings (forward facing thrust arms) are also Mono ball / 2 axis significantly improving brake and steering response. The unique design having 2.5 times the load bearing area of spherical bearings that with their wafer thin teflon liners soon pound out
Currently offering 25% discount which equotes to $360 each
Both include bush extraction tools. Delivery worldwide $40 one kit ($60 F/R)
Old May 13, 2020 | 02:42 PM
  #1802
Jdouble01's Avatar
2010 Mercedes C300 Sport
What size of tires for wheels??
Hello,
I have a 2010 C300 Sport with dynamic handling package. It currently has 18" stock wheels with 255/35/18 tires in the rear and 225/40/18 tires in front. I am going to purchase some KONIG OVERSTEER 19x8.5 5x112 ET42 Opal wheels. I want the same size tire on all four wheels. Should I put 245/35/19 or 235/35/19 all the way around? Both sizes are within 3% difference from stock so I am good there. Will the 245's rub on the front or will they be fine? Thank you for your help...
Old Jul 10, 2020 | 10:34 PM
  #1803
Mensur123's Avatar
mercedes c300
Need advise
Can these 19X8.5 +45 / 19X9.5 +48 5X112 66.6 sized rims fit my c300? And if so which tires should I use so i don't rub.
Old Jul 10, 2020 | 11:00 PM
  #1804
norman.hamilton's Avatar
MBenz C205 250d
have you checked the siites tyre wheel fitting guide? I’d say you’d need 225/35 front and 255 or 265/ 30 rear if the wheels fit that is
Old Jul 25, 2020 | 12:43 AM
  #1805
Elvin Cruz's Avatar
2008 C350 AMG
2008 C350 AMG Wheel Fitment
Hi Im new here.
I just wanted some help knowing if some
20x9 +40 Front
20x10.5 +40 Rear
Would they fit on a stock 2008 C350 AMG?
dont mind rolling fenders and tire stretch.
Thank you in advance for any input.
Old Jul 25, 2020 | 12:18 PM
  #1806
Elvin Cruz's Avatar
2008 C350 AMG
Sick Setup!
Originally Posted by got_thang?
Attachment 382192
20x11 245/35/20 lol
First of all bro sick setups all around. I'm looking for something similar.
What was your setup looking like when you ran these wheel and tires? Bagged or Full coilovers, rear camber kit? Rolled and pulled fenders?
I'm just very curious cuss I really like the way that looks.
Old Aug 2, 2020 | 01:33 PM
  #1807
Gerald Pugal's Avatar
c250
what front lip do you have?
Old Aug 21, 2020 | 06:06 PM
  #1808
Nicholi2007's Avatar
2015 C400 Tenorite Gray
MY RIDE: 2009 C350.
DEALER RECOMMENDATION: 19 x 8.5 either 38 or 40 Offset, 19 x 9.5 - 42 Offset.
I presume 40 would give the front some concave and rear as well.
Q. Too aggressive?
One of the goals is to transfer these wheels to the C43 in the future and have them clear...
Thoughts?
Old Aug 25, 2020 | 02:51 PM
  #1809
Originally Posted by Nicholi2007
MY RIDE: 2009 C350.
Q. Too aggressive?
Thoughts?
Anyone?
Old Sep 7, 2020 | 03:51 PM
  #1810
Dustin Walker's Avatar
2014 C300 4matic Sport plus sedan
Before springs should all fit fine, after springs rear will rub
Originally Posted by pnoyworx
With an ET45 front and rear, you should clear, but may rub with different style tires. Most have recommended thinner brands such as the falken 452's and sumitomo. They have a rounder shoulder than other tires, I believe nitto invo's also have a nice round shoulder to clear the fenders. I am running et 42F/48R slight rubbing in the front with Falken 452's. I'm lowered on H&R C/O's. 25 inches TDC fender to ground all around with a -.80 camber all around. Not sure if I typed the camber reading right, but I'm under a full degree of angle. I rub minimal with just me driving in certain dips, but when the car is full, almost all corners rub minimal on dips or humps but acceptable. At this point there is no apparent tire damage from the rubbing, so that is very very minimal rubbing.
.... From all of my research those sizes should both work front and rear with both being a +45 offset but alot of people say that when 4 adults in the car the rear will rub on bigger dips in the road with the H&K sport Springs but I'm only speaking from a ton or research vs first hand experience! My wheel shop suggested 8.5 front on 45mm and 9.5 rear with 45mm with a 225/35/19 front and a 255/30/19 rear tire and I also plan to get my H&K Sport springs installed on my car as well and with the wheel shop knowing that ahead of time they suggested I get a 225/35/19 front and a 255/30/19 rear and so I ordered a 225/35/19 front and a 255/30/19 rear both in a Toyo Proxies 4Plus All Season Ultra High Performance tire with a 45k mile warranty on them so.... just ask yourself if the 10mm of extra tires width in a luxury car I'd really going to make enough difference to make up for all the potential headaches and then see which size tire you feel you wish to order! That's how I approached it! Hell I wanted a 245/35/19 front and a 275/30/19 rear but my *** was quickly shut down on that there lol ... I just havent gotten my wheels and tires mounted on the wheels or on the car either one yet! Just ordered my tires since we were debating on that same fitment stuff as you are right now since I wanted as wide as I can get but of well it is what it is and a good high end ultra high performance All Season tire on all 4 corners all brand new on brand new freshy balanced wheels is going to make for a beautiful look and a beautiful feeling
Old Sep 7, 2020 | 04:03 PM
  #1811
Those should both fit perfect! I Just had a Rim Shop figure all that stuff out to make sure my car wont rub or eat tires or wear out my wheel bearing prematurely or anything like that there and they suggested a 19x8.5 +45 front and a 19×9.5 +45 Rear so your rear sizes are only 3mm offset difference from what I just ordered so they will Absolutely fit like a glove on your car! These are the wheels I just ordered for mine and now I'm just waiting on my 255/30/19s and my 225/35/19s Toyo Proxies 4 Plus ultra high performance All Season tires to arrive here at the house and then I will have my tire pressure sensors swapped over to the new wheels and put the new wheels on the car finally
Old Oct 5, 2020 | 01:52 PM
  #1812
Count Laszlo's Avatar
'16 GL550, '12 C350
Originally Posted by maxnrelax
My current setup 19x8.5 and 19x9.5 +45
I've been looking to buy these rims for my C350 but the rears are only in offset 48+ in 19". You had mentioned that you had 45 offset for all 4 rims. If you're still around, would love some advice. Thanks!
Old Oct 5, 2020 | 02:50 PM
  #1813
MBenz C205 250d
that’s a long time ago lol. But as you already know I assume the more offset u have the further into the wheel arch the rim goes. You’d need to know what the stock offset is and work from that. The other alternative is a hubcentric spacer. I never had any issues as far as I recall with the 45 offset if that helps.
Old Oct 5, 2020 | 03:41 PM
  #1814
'16 GL550, '12 C350
Haha, old thread for sure.
Thanks you so much for the message. This helps a lot.
Thank you.
Old Oct 25, 2020 | 04:29 PM
  #1815
AAIIIC's Avatar
2014 C250 Luxury
There are a number of big wheel threads, but this seems to be the one with the most recent posts, so I'll try here.
My wife has a '14 C250 Luxury sedan, US spec. From what I can tell it came with 17x7.5" wheels with 225/45s all around. I know that there are some cars that came with 8.5" wheels and 245/40s in the rear. What I'm wondering is what style of 17"s came staggered.
This is what her C250 Luxury has:
Was that style available staggered, or only 7.5" wide?
Or was it is just this style that came staggered in 17"s?
Originally Posted by W205-S
Appreciate some help from those of you who have been around these platforms longer.
Old Nov 25, 2020 | 03:51 AM
  #1816
c220bg's Avatar
c220amg
Et35 18x8j all around
245/40 r18
with summer set up
works perfect
but then I bought winter tires in same dimension 245/40 r18 and now tires poke outside fender
My question is can i put 225/40 front on the same rim width and same offset (all for wheels is et 35 and 8j) or need to bay 225/40 r18 all around.
Also in the picture above you can see how it rubs and I'm afraid it won't twist fender in some big bumps.
Old Nov 25, 2020 | 08:59 AM
  #1817
AAIIIC's Avatar
2014 C250 Luxury
245/40 r18
Yes, you can use staggered tire sizes - some models of W204 came that way from the factory. But 225/40 would not be the right size. Do the math and you'll see that 225/45-18 would match the diameter of the 245/40-18 that you'll still have in the rear.
Edit: I'm curious, what are the brand and model name of the summer tires and the winter tires? That's quite a difference in section width and tread width for tires that are supposed to be the same size!
Old Nov 29, 2020 | 05:11 PM
  #1818
peanutbooters's Avatar
13 c350 coupe
Where’d you get that front lip? Looks awesome
Old Dec 2, 2020 | 11:58 AM
  #1819
Edwin MM's Avatar
2012 E550 178 W212
2014 W204 C300 - OEM Tire, Offset & Bore Question
I unfortunately have nothing extravagant to show here, but out of curiosity with the standard OEM 225/45R17's, can I go down 1mm from the 47ET to a 46ET? Would I have any problems? I found a set of rims from a 2013 Audi A4, looking to just throw winter rubber on them. Specs on www.wheel-size.com seem to match up the bolt pattern, and thread size, but:
i) Audi bore is 66.5, the C300 shows 66.6, any concerns, or just throw a ring on it? Do I need to?
ii) Audi offset is 46ET, the C300 has a 47ET on the OEM rim. Problems?
Much appreciated everyone! Still learning!
Old Dec 3, 2020 | 10:50 AM
  #1820
AAIIIC's Avatar
2014 C250 Luxury
i) The Audi center bore is smaller than the M-B center bore, which means the Audi wheels are NOT going to fit onto your M-B hubs. A hubcentric ring can't fix that!
ii) Look up what offset means and I think the answer will be pretty obvious.
Old Dec 8, 2020 | 12:22 PM
  #1821
c220bg's Avatar
c220amg
winter was Altenzo
I bought new tires so current set up is 225/40 r18,
and for sumer i will bay Michelin pilot sport 4s
Front 8.5j et40 tyres 235/40 r18
Rear 9.5j et45 tyres 265/35 r18
If it does not suit, I will experimenter further.
Rear has to look like this
And front like this
Old Dec 9, 2020 | 07:15 AM
  #1822
c220bg's Avatar
c220amg
Originally Posted by lion.pappa
While I dig through 69pages trying to find the exact size of the wheels im looking for. Would really appreciate it if someones got the answer.
Currently have a 2012 C300 with 17" staggered amg wheels.
17x7.5 et47 225/45r17
17x8.5 et58 245/40r17
The wheels im looking at are
18x8 et32 with 245/40r18
And using a offset calculator I get the following,
Front: Will have 9mm more Inner clearance, and Outer position extended by 21mm
Rear: Will have 32mm more Inner clearance, and Outer position extended by 20mm
Will these be safe to run with the rear increasing 32mm inner clearance? And will they rub?
For 18x8 et35 iz max. for width 245
for et32 you can take a maximum width of 225/235
I have 18x8j et35 245/40 tyres and they rub a little
Old Dec 14, 2020 | 09:28 AM
  #1823
sab202's Avatar
C300 AMG Line W205
I posted my C250 setup in another thread:
https://mbworld.org/forums/c-class-w...ml#post8223758
In short, the combination of AMG Style III R20 8.5"/9.5" ET43 wheels + 235/30/20 front tires + 255/30/20 rear tires should be okay as long as the inner fenders have been totally rolled. But currently I use 245/30/20 front tires, should be 235 though.
Old Jan 6, 2021 | 07:24 PM
  #1824
Blaque Diamond Wheels's Avatar
Former Vendor of MBWorld
2014 S63
Hey guys! Happy New year! 🎉🎉🎇✨
Just sharing our love for the W204 platform with our customer's C63 sitting on our 20" Silver finished with Polished face BD-8 Wheels
Just click on the images to see our full gallery for this project. Enjoy!
***Mention You Are From The Forum For The Best Deals***
Check Out The*All NEW BD-F25
Phone: (818) 362-2300
E-Mail: Info@BlaqueDiamond.com
Website: BlaqueDiamond.com
Click here and visit our pages
IG: @BDWheels
FB: /BlaqueDiamondWheels
Old Jan 13, 2021 | 11:48 AM
  #1825
cotak's Avatar
2008 C300 4Matic Sport
Wheel help
So I’m currently looking at a set of wheels for my W204 4Matic sport sedan..
currently on stock height (will be going bags in the future) and I was wondering about wheel fitment for 2 wheels I may purchase
1. 19x9.5 +45 squared
2. 18x9 +10 squared.
I’m looking to get something that won’t require me to pull/roll the fenders, but have decent fitment until I get my hands on some work meisters. If these fit, what tire sizes would you recommend?
I literally can not figure this out and have looked on fitment industries and Facebook pages to see similar set ups but I’m completely lost. Thank you for any help!
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
