- Mercedes-Benz C-Class and AMG: How to Install HID Headlights
Step by step instructions for do-it-yourself repairs
Browse all: Lighting Guides
C300 HID INSTALL HELP
My first question, is I do not see a normal plug, to unplug from the bulb, that would go into the ballast.
I took the cap off and it looks like the plug and everything is intact inside the headlight assembly (which will not fit a ballast, ignitor)
I understand most drilled a hole in the back cover, and then used the bulbs grommet to create the seal. But how do I access the H7 Plug to plug into the Ballast on the out side of the headlight assembly.
Thank you.
How did you get the bulb in, then clamp it down, then put the dust cap on. It is so tight that I think it can't be done.
anyone have any pictures. 5 hours wasted.
The hardest part is just getting your hand in for the clip.
I shaved a bit of the cap from the edge to that the wires can pass through. I didn't use the gromet that came with my kit.
I used a dremel and just shaved a bit off the edge of the cap so just the wires (not plugs) can pass through. If your worried about condensation you can just use tape to block the shaved area off. I didn't use tape and have no condensation buildup and I've had the DDM kit for roughly 3 years.
I was just afraid to do it to the headlight as far as condensation. I didn't want to have to rebuy a new headlight if I messed up.
you know how the dust cap looks like a [
I shaved (Dremeled) the bottom part of the [ where the thread starts on the edge. Just enough so that the wires can pass through.
Drilling a hole and using the gromet is probably easier. Drill a small pilot hole then increase the size of the hole until you can fit the gormet in.
Hole needs to be a little bigger to fit a protruding tab on the side of one of the connectors. The BMW dust cap that DDM used in their instructions is flimsy and can be stretched but our dust caps are rigid. If you do some searching, I think I had a picture of my dust caps with the grommets/wiring in posted in one of the threads.
I don't think many people adjusted their projectors downwards. I have 55w 8000k installed for a little over a month now, and I haven't been flashed by oncoming drivers yet. I've also asked quite a few coworkers that have driven in front me coming in and leaving work, and they said, surprisingly, my lights look fine/are not blinding when seen from their rear view mirrors.
