Steering pulling opposite way
Ive noticed that my steering sort of jabs in the opposite direction while turning.
So for example while turning right into my driveway or at even a slight bend at high speeds (on the highway for example), my steering wheel tries applies force in the opposite direction (left). Its not a constant pull...pulls then if I hold it steady it goes back to normal, then pulls again and back to normal.
Im guessing this has something to do with the power steering system, but anyone have any clue?
The question is, where is the fluid going?
But still the same,but when turning full lock i get a grinding noise sounds like its coming from the power steering pump then when pulling the other way it stops till i get to full lock again,there is a pipe that comes off the powersteering filling tank and when turning goes really hard then lets off dont no if this is normal,but what could this be still ??
Have you removed the plastic cover under your engine to view for power steering fluid leaks?
