How to use HOLD function in new C class?
Rating: Thread Rating: 3 votes, 5.00 average.
Old Oct 8, 2011 | 10:26 AM
  #51
kevink2's Avatar
2004 Mazda6, 1993 RX7
Originally Posted by RLE
You might say that since this subject came up several years ago and I posted the same thing then.
I might also say that repeating a point identified just 5 posts before, in the same theread, the prior day, is more appropriately characterized as an echo, vs a common repeat of th point years ago.
Old May 11, 2017 | 03:07 PM
  #52
geoffs's Avatar
C250
Question Brake Hold Function
Ok, so I got my new (to me) C250 (2016) just a week ago and use the brake hold function, works great.
However, this morning I was stopped at lights and the engine autostop kicked in, so the engine stopped. I applied the brake HOLD function and all good. The junction was a bit mad, so I was sat there for a bit, then the engine restarted as the autostop timed out and the brakes released and the car started to move forward. Very disconcerting!!!
So at the next lights i did the same again, but this time pressed the deactivate on the autostop and the engine started up, but the brakes remained on!.
So the question is, what is supposed to happen?
I would have thought that the brakes should not release unless i want them too, not when the autostop times out?
What experience do you guys have of this???
Thanks.
Old Mar 8, 2025 | 01:54 AM
  #53
Huleyman's Avatar
E53 (2025), C300 4MATIC (2014)
Hoping this is the right place for this discussion:
Brake HOLD feature, which I have used for 11 years in my 2014 C300, is suddenly intermittent for the last 2-3 weeks.
Some days it works for a while, or only after a few miles, and others it doesn't work at all. Others it works right away, all day. The last month I have noticed it fails in a similar scenario that may have worked the day before. Brake pedal doesn't feel more or less stiff than anytime in the last decade. Wondering if this sounds like regular wear after a decade or so, or first time you've heard of this failing inconsistently? Maybe time to buy a data port reader to see if there is something off, or just bring it to the dealership and set my money on fire?
Old Mar 8, 2025 | 10:28 AM
  #54
W205C43PFL's Avatar
Check for codes, check the 12V battery, check the aux battery.
Old Mar 8, 2025 | 06:37 PM
  #55
Huleyman's Avatar
Got an OBD2 reader. No error codes. Brake HOLD worked today for 10 minutes while testing just to further puzzle me.
Forgot to check 12V battery directly, but OBD2 reader said the "Control Module Voltage" was 7-8V while engine was off, then shot up to 13-14V while the engine was idling and I drove a little. Not sure that tells me anything about the 12V battery. If I drive about 4 miles for my commute (same for 11 years) is that enough to keep the 12V battery topped up? About 80% surface streets. Less than 2 mins on the highway.
How do I check AUX battery (new to me)?
Old Mar 8, 2025 | 06:47 PM
  #56
W205C43PFL's Avatar
Is the scanner capable in reading MB related codes?
Old Mar 8, 2025 | 08:30 PM
  #57
Huleyman's Avatar
I did a comprehensive scan and 4 blue notices (not warnings) came up that were particular to my car. It knew all the specs for my car while I looked at the detail on the notices. Once I started the engine and did another scan the two notices (seat adjustment and ESP) disappeared. The second one was "ESP(R) - Electronic stability program (N30/4): The power supply is outside the valid range"
I bought the OBD2 reader last night: BlueDriver
Amazon Amazon
Old Mar 8, 2025 | 09:13 PM
  #58
W205C43PFL's Avatar
https://www.amazon.com/dp/B00652G4TS
I see, those won't affect auto start/stop though.
Old Mar 8, 2025 | 09:14 PM
  #59
W205C43PFL's Avatar
Sorry about that, I forgot to answer your aux battery question, see this thread: https://mbworld.org/forums/c-class-w...y-battery.html
Old Mar 8, 2025 | 09:15 PM
  #60
W205C43PFL's Avatar
Sorry about that I mean auto hold.
Old Mar 8, 2025 | 09:17 PM
  #61
W205C43PFL's Avatar
I can't stop saying sorry tonight, sorry again, just realized the W204 might not have an aux battery.
Old Mar 8, 2025 | 09:19 PM
  #62
W205C43PFL's Avatar
Try using something called Launch CReader Benz, it might detect some missing codes but I can't guarantee that, I don't hear BlueDriver being talked about much on the forums but I do recall hearing it.
Old Mar 8, 2025 | 11:24 PM
  #63
Huleyman's Avatar
This reader was chosen after only a paltry amount of research (less than most here would likely do). The main reason was that it had reasonable reviews online, would use the smartphone for the screen and not require subscriptions for future use. Finally, and embarrassingly, Amazon said I could have it in 9 hours if I ordered now... and I muttered to myself "what a time to be alive" and clicked purchase. I am happy that less than 12 hours after wondering if there was an obvious fault, I now know I need to dig deeper, pay more attention to the symptoms, and then chill out in 2 weeks when my 2025 E53 is delivered.
Old Mar 9, 2025 | 09:43 AM
  #64
W205C43PFL's Avatar
no subscriptions are needed if you buy the Launch CReader benz version but you are given the option to buy an annual one for other makes.
​​​​​​Ah I see, enjoy the new vehicle! Congrats : ) W214 will be too new for the Launch CReader anyways.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
