Spirited Driving?
I plan on buying a 2012 C350 Sport here in the next couple weeks (can't wait!). I am just wondering how do you guys drive your C-class?
By that I mean, are you guys hard on the gas, how do you guys take turns? Etc.
I am pretty hard on the gas and like taking turns at a speed most people don't. I currently driving a Lexus GS300 and its holding up very well with the way I drive except it feels like a tank.
I have been debating between the 07-08 TL-S, IS350 F-Sport, and the C-350.Since my whole family and I are all Lexus buyers, I decided to change it up a bit and try a Mercedes. My cousins have had a few BMW's which are really fun to drive but not fun to repair which leaves me to get a Mercedes.
I just wanna know how well the C-class is holding up and how you guys drive it. Would I be okay buying this car if I drive a little more spirited? I'd really appreciate your help.
The W204 is a much more reliable car, but it still doesn't have me convinced. I leased this one for the duration of the warranty - taking no chances!
I plan on keeping the car completely stock through winter besides tints. Then when spring comes by, I plan on getting some different wheels along with springs.
I just want to make sure that this car can take a beating as Lexus has never let me or my family down. I can beat on the GS knowing nothing will happen as with my cousin and his BMW's, he didn't drive it hard because he was afraid something would happen. He has left German engineering and went back to Lexus. He told me to "Beware" lol.
If you buy, and you have muli-family drivers, I would suggest modest drop springs as someone said vs sway bars, as the bars make your wonderful independent suspension less independent.
When the C300 lux was purchased, we test drove a similar BMW and Audi 6 cyl awd's with a/s tires. The Mercedes was more comfortable and less "sporty", but I had no trouble matching ultimate performance on the back roads, getting some air occasionally.
For the record, my Audi A4 was more reliable than my Honda Accord. So much for statistics...
What an ignorant post. Virtually all manufacturers use some form of variable valve timing today. The IS350 would certainly show you its tail lights - "fuel saving" VVT-i and all.
Modest spring rate increases (~30%) will not provide the performance you described of Eibach bar upgrades, but they will match the sportier rides of the related OEM BMW's, while maintaining the pure independence of the suspension. Sway bar single-wheel rate increases vary, but Eibach's typically are 50-80% (need to verify) and have a related 100+ % net change in single wheel joust rate.
Springs are still softened by the load path, which include a top rubber pad for struts, and control arm bushings as well as an occasional spring perch pad for wishbones. The sway bar upgrade includes stiff poly bushings at the pivots, where a little give with rubber is amplified my the MR (Motion Ratio). Oem end links still supply some cushion.
The sway bar rules in comfort when you go over a development speed bump, square to the bump, as it has no suspension stiffening effect.
I put sways on a car that had none (Saab 900T), have a pair of sways for my 7 that only go on for HPDE summers (oems for rest of year), and designed and built an adjustable rear bar (9/16") for a car I autox'd and hit the big tracks with (Triumph GT-6, no oem rear bar). That last car I had 2x rate oem Race springs, and I disconnected the bars offseason, and ride quality was great, considering the rate increase.
At the big track, a guy with another 7 could not get through a high speed rough tarmac turn without drifting outward ... he had the biggest bars he could buy ... I had no issue with basic Eibach bars.
Looks like you are comparing a 07-08 Acura TL type S, Lexus IS-F, and C350.
Well, #1, IS-F, 415Hp is no match to the C350 and TL-S. You should be comparing a C63 vs. IS-F
Out of the other two cars, I'd say Acura TL-S, because it is a honda and has a V6 motor that is super reliable, cheap to fix, and good on gas. No doubt the car is sexy as hell too.
TL-S takes this one compared to the C350. IS-F is in a whole other league.
Good luck on your choice!
They are sized for the Majority of owners, who like the ride and don't upgrade the bars.
Totally Agree.
Totally disagree.
To each his own. For pure flat cornering on smooth roads, bars. For less flat cornering but better suspension quality, springs.
Would tuning the ECU effect anything or risk anything towards the engine? Besides me beating on it lol
