Sprint Booster Review
Also the sprintbooster doesnt effect the shifting of the trans
The SB does not reduce throttle lag or latency. That is built into the ECU & can only be corrected in the ECU. It does not increase performance.
Sprint booster reduces throttle control by electronically shortening pedal distance and might fool you into thinking lag is gone, but does not reduce lag at all - it's truly impossible for it to reduce the lag because it is only altering the signal from the gas pedal - not from the ECU to the engine. This is verified by reviewing their patent filing which explains how the product works as an amplifier. There are dozens of threads about this and a very good white paper that explains it. There is also a thread in which the Sprint Booster people participated and were unable to prove our statements or the white paper wrong with any facts or material of their own. Please search and read about it.
I do have to disagree about the lag though, these vehicles are extremely laggy and I do wish there were a real way to reduce the lag - I'd be all over it.
"All it does is make the car think the pedal is being pushed further down than it actually is", "I can do the same thing with my foot", "it is all in your head", the """scientific""" white paper proves", cannot control the throttle in traffic???" ...These opinions are from those who have Never had a sprintbooster or drove a car with one installed.
"The car is much more reactive from the hole as well as on the highway when passing", this is how the car should have come from the factory", I enjoy driving my car in daily situations much more since installed", "best $300 I have spent on this car","easily adapted to the response - green mode is perfect in traffic", These are from those of us with the sprintbooster in our cars - It is an excellent product.
Couple things:
I read recently that it was not favorable in a turbocharged 250, cannot disagree as I only have experience with my naturally aspirated car. Some knucklehead in that thread said they were arguing against the product for years??? wth? Why argue against something you never tried? And what gain is there trying to talk someone else out of it?
The white paper that is often mentioned is well written and has a couple nice graphs - far from scientific, as the guy who did it was trying his best to push the gas pedal the same distance and speed but all with the human element involved - it does do what he set out to do, prove the sprintbooster does not make the car faster, which the company never claims to do..Proves nothing about the fun factor it adds to everyday driving.
I highly recommend this product - I truly appreciate driving this car more now than I can explain without somebody actually sitting in my car and driving it - if you do not like it - You Never Tried It....guaranteed.
Couple things:
SB does not reduce lag. Period. It amplifies the throttle signal and reduces the useful throttle distance.
If you enjoy the effect that the product has (and it certainly does have an effect!) then that is perfectly fine. I just don't like it when people misunderstand the product and make false statements about what the SB can and cannot do. It cannot reduce lag. It does not reduce lag. You can achieve the same with your foot in a non SB vehicle. I wish it did reduce lag, I really do because I'd have one in my car.
And by the way - there are plenty who tried it and agree. Scroll down in the W204 forum - there is a user who recently bought it and is returning it since it didn't reduce his lag. Guaranteed!
Since these threads always devolve into very silly useless argument and all of the proper facts are readily available for a logical person to make up their own mind about the SB, I will not argue further in this thread unless it is to post something useful / substantial. Have a very happy holiday!
The SB uses linear, straight curves, according to the white paper test on an older model. Even if it used the same 100% pedal travel, it would feel like it had more response.
With the old SB the car adjust itself back to the slow response, are there any users out there that have had the old version and switched to the 3 mode version? just want to know if you still need to do the reset every now and then?
So essentially, a SB will give you the desired downshifts for strong pulls nearly everytime without having to ALWAYS floor your gas pedal to the metal.
Read below:
http://mindhacks.com/2007/12/17/cogn...nce-reduction/
jctevere makes a valid point the OE industry understands as well. Mr prior company attached gauges to throttles and allowed folks in a research project to drive around for an extended period. When the data was analyzed (and I do not remember the numbers), they were surprised at how little throttle angle was used by most drivers and how almost non-existent were occurrences of wide open throttle. In follow up work, they did conclude that most folks are not comfortable pressing to WOT. To the degree that drivers here are also so disinclined to move their foot, as if it somehow just doesn't feel natural to them, the SB can do that for them. That sense of relief, while still getting the result, may be the basis of many of the SB fans, as technically, we all understand nothing else changes.
As always, an interesting discussion with you
BTW, I sent an e-mail to SB about "better response up to 100% pedal travel". No reply so I resent same email, and they said they had to send it to main engineers in England, UK, whatever. Still waiting ...
See my response to Glyn below. If the WP Figs 1&3 are still true, it gives the most boost or highest gain in throttle response at low inputs, like up to 1/4 pedal travel. I'm not sure of the SB tech's info about "rate of change" as the total basis for the SB. Looks more to me like a linear curve is assumed, and rate of change is then used to create a linear response.
The only way to prove your theory here would be to directly input a step-function signal to the ecu of about 1/4 throttle and see what the lag is.
I don't think the 'response' improvement should be confused with lag reduction because you still end up with the same lag if you just pushed the pedal a bit further / faster on a non SB vehicle. Maybe you could explain your thought with regards to that in another way? I'm not sure I completely follow.
To test the ecu lag, a simple data-log of TB position vs Injector duty cycle (non-DI) would show this, I think.
