Service B
Service B
Contactee MB of chicago for service B and this is what I got
"Hello Tasho,
B Service includes:
Change engine oil and filter
Check and adjust fluid levels
Visually inspect brake pads rotors
Inspect interior and exterior lamps
Replace dust filter
Check and correct tire pressure
Check ploy-V belt
Inspect all belts and hoses
Replace windshield wiper inserts
Inspect and rotate tires
Brake test and measure rotors with micrometer
Reset the FSS counter
Tina Keene
Service Coordinator | Mercedes Benz of Chicago
1111 W. Division Street | Chicago, IL 60642 | Office (312) 628-4444 ext 6508 | TKeene@fletcherjonescompany.com"
Is this what service B includes? And he told me its $500 and it would take the whole day to do.
"Hello Tasho,
B Service includes:
Replace dust filter
Check ploy-V belt
Tina Keene
Save some cash. Get the oil and filter change done and just buy the dust filter. Check everything else yourself and change out the wipers if they need it along with the cabin filter. I'm getting my brake fluid flushed with the oil change and I'm going to reset my counter myself if they won't do it. That's about $200 cheaper than the dealership here in Columbia, SC quoted me for service B.
I am lucky to have a service book which tells me every detail of the A & B Service.
It also tells of the additional work required on a yearly & mileage basis.eg brake fluid, ATM oil change , air & fuel filter spark plugs ect.
IMO I suggest you research what needs to be done then tell the dealer to do it.
Then you are in control of the servicing of your car ie the correct items at the correct time .
Good luck & enjoy being in charge !!
2018 E300 4MATIC Sedan
Tasho,
Hope this helps :
https://mbworld.org/forums/c-class-w...know-what.html
https://mbworld.org/forums/c-class-w...-180-days.html
Nick
Hope this helps :
Nick
2004 Mazda6, 1993 RX7
And whats more your are sure that it has been done & properly with the correct oil & filters .
