New 236.15 Fluid for 722.9 7G Tronic Plus imminent.
Super Moderator
The new transmission Fluid requirement for 722.9 7G Tronic Plus automatic transmission as of production date 21.6.2010 except vehicles with engine OM 629. Lower viscosity for energy saving & longer life in service.
Release of approved products listing is imminent. I will post as soon as I receive.
They are running a little late!!
BTW - the new fluid is Blue for easy identification.
Super Moderator
You could tell by down shifting with your shifter and then up shift consecutively until the the number next to D is gone. If the last number you see is a 5, you must have the 6 speed, if the last number you see is a 6, you have the 7 speed.
edit: True, the vin would probably be the most reliable way, I believe there is a Mercedes vin decoder website somewhere out there.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
If your car is not a 4matic, then chances are its the 6 speed (I don't know the internal code for it), unless it has the optional 7 speed which is what this thread is about.
Super Moderator
The 2012 facelift models are certainly available with Stop-Start & the 7G Tronic Plus should be fitted to all cars with the new M271 Evo Turbo engine & the new M278 60 degree V6. You will note new owners talking about S & E mode with default to E.
I can't comment on runout models to the US.
EDIT: Yes - fluid change every 125,000Km's instead of 60,000Km's (they say 50K in the article but 60K has been the global norm). We will see how this works out in reality.
C200
Hi Glyn,
Mine is a 2008 W204 5-speed AT C180K.
My mechanic told me that the newer 7speed ATF fluid can be used in mine.
Is that true?
Thanks in advance.
Is that true?
Thanks in advance.
Super Moderator
No - the new 236.15 Blue transmission fluid is for 722.9 Plus transmissions only. The present formulation is not reverse compatible.
Easy to understand and answers this very question.
C200
Glyn, thanks for the prompt reply.
Just got more info from my mechanic pertaining to the ATF.
It's ZF Semi-Synthetic 236.14 specs.
I suppose that should be the correct ATF for my 2008 W204 5 Speed AT?
Warmest regards,
Ricky Liew
Warmest regards,
Ricky Liew
Super Moderator
Yes - 236.14 is the correct fluid for your transmission.
Interestingly however - ZF does not hold an approval for 236.14. Being a transmission manufacturer themselves it might be someone else's product repackaged. They are still required to request a read across & listing.
Make sure the packaging states Approved MB 236.14 & not the usual BS "Suitable for" game that some play.
Super Moderator
https://mbworld.org/forums/attachmen...00-7g-plus.pdf
We will soon be launching a Wiki which will have all of this info in one place for easy reference. A monumental task that is going to require help from members to keep populated & relevant.
Super Moderator
New 236.15 Approved Products for 722.9 Plus transmission
I just found this YouTube video on 7G TronicPlus, it mentions the W204 at the end. If W204 has START/STOP function, then you have it.
here's the link
http://youtu.be/7tfiowxUTBs
AC
Super Moderator
If the base transmission is a 722.6 you cannot use the new fluid.
w124
So I know I have the 7G Tronic Plus since I have a U.S. spec C250 BlueEfficiency (MY 2013, build date 6/2012 in South Africa), even though I DO NOT have STOP/START function.
My manual doesn't state what the capacity is for the 7G Plus for my M271 engine. Anyone know? Thanks!
Check this dealership out in Orlando.. They claim the C250 with 7G tronic plus.
http://www.mercedesbenzsouthorlando....USC30MBCA62B0/
AC
Red 2001 SLK230, Black 2011 E350
