Seven speed sport transmission
Old Mar 23, 2012 | 01:14 PM
Fraggy's Avatar
BMW 335i
Hello everyone, I'm new to this forum and I'm considering a C 350 sport. I have a question about the transmission when it's driven in manual mode. My question is, how well it holds gears during run off.
So let's say you're accelerating in a particular gear and you get to say 3500 RPMs, and then you let off the gas, does the transmission disengage or does it stay fully locked into the gear as a manual transmission would?
I have not had the opportunity to drive one yet to see for myself so I thought I would ask the smart folks here on this forum.
Old Mar 23, 2012 | 04:10 PM
cswang's Avatar
2012 C350 Palladium Sport Sedan
Not sure since I don't have the dynamic handling package so be sure to get the dynamic handling package.
Old Mar 23, 2012 | 04:42 PM
Fraggy's Avatar
BMW 335i
I didn't see that listed as an option on the website
Old Mar 23, 2012 | 04:55 PM
cswang's Avatar
You need it in order to shift manually. Otherwise you only shift down, not up, if I understood the manual correctly.
Old Mar 23, 2012 | 05:25 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
all cars have the tiptronic trans if thats what u mean. If you mean M mode next to the shifter u have to have dynamic handling package, I have it on my 2011. It lets u paddle shift OR stick shift up and down, it holds the gears better than sport mode in a regular car, but does NOT lock the gear like a manual. If your in 5th doing 15mph and hit it the trans will kick down a gear maybe 2 gears to help you out instead of ******* the gear. What it does do is hold the gear til the end, it redlines for a sec before push shifting u to the next gear, its great for the track or spirited driving
Old Mar 23, 2012 | 06:00 PM
Fraggy's Avatar
BMW 335i
I guess the 2012 models must have it standard because I did not see the dynamic handling package listed as any option or package on the build your own website and the coupes standard with paddle shifters.
Old Mar 23, 2012 | 06:22 PM
to go into detail........it was a 2k package and it includes, the paddle shifters, next to the shifter is the button normally c/s but on these its ONLY M mode. on the dash is a sport button next to the rear power shade and heated seats. That engages the sport mode on trans and activates the sport suspension which is a magnetic ride control system that is very firm and responsive. These cars use different shocks/struts/swaybars than standard C class. If anyone has a 2012 w paddles let us know if you have the M button and the Sport button on the dash, id be interested to know if its standard now, I highly doubt it tho....
Old Mar 23, 2012 | 06:43 PM
DCubed's Avatar
C250,GLK350
Dynamic Handling Pkg is still an option on the facelift cars.
Old Mar 23, 2012 | 06:51 PM
MDMercedesGuy's Avatar
2024 GLS450
There are several options (dynamic handling, rear sunshade) that are not listed on the website but that are available.
There is an additional fee to order it - I think it is like $250 + the cost of the option.
Old Mar 23, 2012 | 06:56 PM
DCubed's Avatar
C250,GLK350
Yep it is considered a special option which springs up the $250 special order surcharge. Luckily it is a one time option and not a $250 charge per SO option.
Old Mar 23, 2012 | 09:40 PM
i thought so, i cant see it being standard, it was almost 2grand on my 2011. I would recommend it to anyone who is an aggressive driver, its the bomb. The only caveat is you cant do coil-overs to lower the car if you have that option, but you can do springs. it lowers the car even more than usual cause its already a little lower than standard Cs.
Old Mar 23, 2012 | 10:02 PM
Fraggy's Avatar
BMW 335i
Thank you all, this is great info.
Old Mar 25, 2012 | 01:06 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
To simplify, manual mode allows you to select a new, lower, top gear, that's it. Select 4th and come to a stop, your down to 1st, and you then hit it and it will shift to 2nd, 3rd, then 4th as top gear.
Post_5 by Jimmy explains the behavior well.
Old Mar 25, 2012 | 04:31 PM
Fraggy's Avatar
BMW 335i
If u can't down shift, what's the point of the paddle shifter with a minus symbol in it?
