Basic Oil Info Summary
Viscosity
The 2009 owners manual has the typical MB viscosity chart shown:
2009 Oil Viscosity Chart
This chart has changed abit through the years. The current 2012 chart can be found on page 330 of this large PDF file of the owners manual:
http://www.mbusa.com/vcm/MB/DigitalA...lass-Coupe.pdf
The 2012 chart has the same basic range of -13F to +86F, for the two widest temperature ranges of the 5 groups shown. 0W-30 and 0W-40 have extended useful temperature range, denoted by wide, black arrow heads at the top and bottom of the basic range.
The Mobil 1 229.5 gas engine oils, used by most dealers, has a 5W-40 viscosity rating, and falls in the slightly more restricted range that does not have an extension to the basic lower temperature limit, -13F .
The 2008 C300 4MATIC has run the approved Castrol 0W-30 oil from the 2nd oil change, and appears to be working well, and offers 2mpg better milage on trips than the 5W40 from the dealer pumps.
Approved Oils
These are listed in the MB fluids list, as 229.5 for current models:
mercedes-benz 229.5 approved oils
An excellent oil thread from Glyn:
definitive approved engine oil requirementsl
DIY Changing Oil
Oil Change Mega-Thread
Other Oils, Not Approved
I personally have run transmission and axle oils in my Hard Tracked Rx7, including Redline and Neosynthetic. I ran Amsoil Synthetic grease in my tracked car's front wheel-bearings, back in the 80's when few synthetics existed other than industrial greases. These performed well for me, although I did change them often.
I'm sure some oils from non-approved brands would work fine in the W204. If you want to take that chance, it's your car.
The Magnuson-Moss Act
No warrantor of a consumer product may condition his written or implied warranty of such product on the consumer’s using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name
This part of the act seems to weaken the claim that any oil can be used. MB specifies a host of varied brand synthetic oils, and I don't believe Amsoil's statement that just viscosity compliance is all that must be satisfied for MB. Also, many of Amsoil's proud comparitive tests are on oils that are not approved by MB. That seems below Amsoil's good, long reputation.
FWIW, Some of the work I've done in an industrial environment included dealing with lubrication, and lubricant specification. From oil mist systems for ball bearings running at 400F and 5K rpms, where the oil mist was not visible in the clear feed tubing, and specifying experimental boundary condition greases (Krytox + Moly Van-A) with high Timken OK specs for 500F operation of spherical roller bearings at slow speeds.
My favorit project was total design and specifications for the 3-spoke bike wheel that Lance Armstrong won most of this TDF time trials with.
3-Spoke Graphite-Epoxy Bicycle Wheel --look for my name in the screen shot of wheel stresses
______________ *** All Members, New and some Old *** _______________
please click on User CP at the top left of page, just below the thread title. Then add the following to either Profile and/or Signature , selecting buttons on the left side of that page:
year, model, if it's a diesel, Sport or Lux, 4MATIC or RWD, Location (city & state), and non-US country if applicable.
This helps others respond to issues, like tires, spring options, part sales, etc. Thanx
:https://mbworld.org/forums/c-class-w...sers-here.html
Its nice to have another person specializing in that field voice their advice/opinion. Its valuable information to all DIY-ers.
I should note that a number of Polyurea & Lithium Complex synthetic greases manufactured by the industry will give superlative results in high temperature, high load situations & even in the presence of sea water.
EDIT - Any grease that can pass *** FE8 & especially *** FE9 will be unbeatable. We have a grease in our armoury that we can run to 10,000 hours in the FE9 test with no sign of failure in sight. To put this into perspective the best from the German specialty companies like Kluber etc. fail at under 5000 hours. We also run modified versions of these tests at other speeds.
*** FE8. (DIN 51819) and FE9. (DIN 51821)
1) use an approved (or a non-approved high qualiy ACEA A3 oil, if you want to assume some risk and potential hastle).
2) use an XW-30 for mid to northern colder climates, or non-usa equivalents.
3) use an XW-40 for mid to southern climates, esp places where hitting 100F is not unusual.
Obviously with base oil viscosity adjusted for speed unless you use resins with lower viscosity.
I admit a preference for Polyureas having done a lot of work with Voest.
Of course these products work really well in automotive applications but are overkill unless you have a specific problem.
In high volume heavy industry, Metals, Paper, Cement etc. etc. bearing & gear our main competition has always been Fuchs, Kluber & Carl Bechem.
In modern Steel plants including Stainless where things are well cooled we are talking max temperatures in the 200 deg C area. The worst I had to contend with for many years were crap old Doncaster Engineering concasters where the strand leaves the cooling chamber onto the badly cooled & ventilated cut-off rolls & temperatures were consistently 300 deg C. Re-lube approx every 12 minutes. All bearings C4's obviously.
I have seen considerably higher temperatures measured but with your experience I'm sure you have seen temperatures measured by whatever method, paints, thermography, thermocouples, pyrometers etc. that you don't believe the lubricant is being subjected to. Taking meaningful temperatures in some applications can be really difficult.
https://mbworld.org/forums/clk-class...ghlight=Amsoil
And
https://mbworld.org/forums/c-class-w...ghlight=Amsoil
I could not be bothered to repeat myself.
And indeed - I am a tribologist. See my profile.
Monogrades ~ as they include no VI improver ~ shear very little. Especially VHVI synthetics.
Regards,
Don
I would just like to use it since I have it. I'm in Texas, so warmer climate, but it's winter and I'll be changing it again in a few months anyway. '08 C350 Sport. Thanks.
