Service B
Just a general question for those of you who have gotten this done. What can I expect? What exactly is done in this? What are the costs/expenses involved? Just make an appointment with a dealership, tell them service B is due and bring it in or what?
Thanks guys.
Anyone who recently got it done, any ideas? What did you end up paying, etc?
If service B is also an oil change (I thought they do something with brake fluid too but I guess not), why do people just keep going back to MB at their prices? Is it a warranty thing? Meaning if it's not on record that it was done and something fails, they don't cover any part of your vehicle? That thread indicates not true, but that was a while ago.
If it's just an oil change pretty much then I rather get it done from some regular shop and figure out how to get rid of the sign on the instrument cluster. As someone mentioned it can be done at home by yourself?
I am sure the shop that changes oil would most likely do the brake fluid flush as well if needed. Seems like that would deff be a cheaper route to take.
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
Needless to say after i researched a bit and looked at the checklist that they use, i went to MotorWerks in Commerce for an Oil Change lol. The rest i can do myself. Saved a ton of monies!
However, lol, a lot of service advisers will WORD it as if this a la carte item were part of Service B and have you believe a service B costs like $400-$500.
You'd be surprised how many people just go, oh okay.
How can I reset the meter then? I can take it to the dealership once the Service C or the next oil change is due for an overall check up? How does that sound? I do fair bit of driving. The car just clocked 41K km's. I purchased with around 32K or so in the end of March.
You may have to first go to http://epc.startekinfo.com/epc/ and then select Star Tekinfo in the left column. Then select MB Workshop Resources on the next page.
http://epc.startekinfo.com/epc/ and then navigate to STAR Tekinfo showin in the left column
but Question.... do you guys think it's necessary for a brake fluid flush at 20k? (service b)?? I think it's ridiculous ... they are just adding all these unnecessary things to the "SERVICE" so they can justify the price...
Should I bother with rest of the things like brake fluids etc?
Rest of it all seems like inspections like wiper and what not. Is that all necessary. I really don't feel like getting ripped off by paying $400 or so for nothing.
Asked them if I were to follow the maintenance schedule and get the service B done, I got quoted $750-$790! HOLY FAWK!
