Is it worth will investing in a Carlsson C-Tronic tuning box?
Yours faithfully,
Lewis from Scotland.
So it would be like same oem boost profile and a 2.0L engine, rather than 1.6L, as far as low end pull.
Not sure what other ecu upgrades you had available ??
Tuningboxes are all the same Carlsson , Vath , speedbuster etc.
They al give the same figures.
Search TMC motorsport, also the same and cheaper.
I have one from Diesel-Power.com
Now with the CGI it depends were you buy it, in The Netherlands they are all 1.8L (180/200/250CGI)
But UK and Germany seems to have a C180 CGI 1.6 with 122 hp and a C200 CGI with also an 1.6 with 156 hp.
Now I'm even more confused.
Here in Australia, we have the C200CGI - 1.8L. I'm not sure about the C180 or C250.
http://www.kleemann.dk/Performance/E...I_M271EVO.aspx
The diesels are C200, C220 and ÇC250 all 2.143L with various degrees of tune, and the C350 which is a 2,987L.
So tuning is definitely an option, especially on the CDIs where huge gains can be obtained. The question is who will give the best for the investment.
I have a 180CGI with 1.8L , the 1.6L isnt available here.
So it depends on w you live.
In any case this is a thread about the value of an ECU tune, for which ANY MB engine can benefit.
With an ECU tune you can get much gain with turbo engines.
So I'll compare the hp and Tq gains for Carlsonn vs Kleemann vs JuiceBox, hp & ft/lbs :
HP, Tq
40, 44 > Carlsonn
42, 37 > Kleemann
07, 40 > JuiceBox Burger
I believe the 1st two are complicated tunes that include discrete changes in the matrix table points of timing & fuel. This allows them to add advance to let the boost rise quicker with less delay. They may also do a minor SprintBooster mod for quicker throttle response. I think it's all accomplished by a box that connects to the ecu.
I talked with the JB guys, and as I suspected they do a global change to the fuel to lean it out, and do what looks like a scaler change to the boost map, with little change at the top end. Based on their bef/aft Dyno runs (and my talks with them), you can see they did not change the timing to help reduce power lag. But if you just want more low end torque, and as-is lag does not bother you, this is the best deal on more low end torque.
https://mbworld.org/forums/c-class-w...0cgi-tune.html
