C300 Staggard Wheel question
Old Oct 17, 2012 | 05:58 PM
smileyworm's Avatar
C300
Hello everyone!
I have just purchased a 2011 C300 sport. I am in the process of trying to replace the stock wheels which I have been told are 8.5 inches in the front and 9.5 inches in the rear of the car. If I replace all 4 wheels with an 8.5 inch wheel would there be any issues with handling? I am also wonderinghow bad the loss of that inch would look under the rear wheel wells?
Thanks in advance as this is my first MB and I want to treat it right.
Here are the wheels that I am looking at if anyone is curious:
http://versantewheels.com/wheels/ind...sante-222.html
Old Oct 17, 2012 | 06:09 PM
aMsupp's Avatar
C300 Sport
Originally Posted by smileyworm
Hello everyone!
You could do it, but you'd need spacers on the rear. Also, you will have less traction (obviously due to less contact patch on the road). Just a couple things to mention. Otherwise if you really want to do it, you'd probably be just fine.
Old Oct 17, 2012 | 06:12 PM
smileyworm's Avatar
C300
Sorry, for asking but what are spacers?
Also, what grade of fuel should I use?
Sorry, can you tell I am not a car guy.
Old Oct 17, 2012 | 06:39 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Are you sure about the rim size? 17" OEM wheels are F-7.5 R-8.5. BTW- your car REQUIRES Premium fuel. Don't try to save money on Regular. If your car allows E85 (Yellow Gascap)- avoid it. It may be cheaper and even though the car is approved for it- it is a very corrosive fuel which decreases fuel economy.
Old Oct 17, 2012 | 06:53 PM
smileyworm's Avatar
C300
No, I am not sure abou the size but i do know they are factory. So, the spacers go on before the wheel to move it out closer to the lip of the wheel well, correct? Is there anything bad about having these on?
Old Oct 17, 2012 | 07:10 PM
white46's Avatar
08 C300
1. even though it requires premium fuel, it won't hurt to use regular. Having said that, I always use premium. lol
2. staggered or non-staggered. It doesn't matter. aMsupp said there will be less grip on rear, but c300 isn't all that powerfull to make it into consideration either. Upside of having narrower tire is increase in fuel consumption. But then, having narrow tires usually looks cheap.
3. Spacers are not something you need. With spacers, it will just look better.
Old Oct 17, 2012 | 08:19 PM
aMsupp's Avatar
C300 Sport
1. It DOES hurt to use regular. Don't mislead him. It will run **** poorly, knock, and cause premature wear and tear.
2. The C300 has good torque, which is what's needed to break traction. It will break traction with narrower tires if you punch it.
3. Without spacers, the car will have ridiculously tucked rear tires and will look like a mexican show car without a dropped suspension. AKA
Just my .02!
Old Oct 18, 2012 | 01:23 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
The canadian c250 doesnt have staggered wheels and I don't see a huge difference on the look at the rears. Only use premium everytime. only use the regular stuff in emergency situations only and don't rev and load the engine too much.
Old Oct 18, 2012 | 07:54 AM
smileyworm's Avatar
C300
Thank you ALL for helping me!!!!
If the fronts are factory 7.5 and I am putting 8.5's on, will they look bad because they will be sticking out?
Old Oct 18, 2012 | 07:58 AM
smileyworm's Avatar
C300
I am buying this 2011 car used with over 25,000 miles on it. This was a fleet vehicle and I am sure the engine was not taken care of. Any help with what maintenance I should do? Fuel additives, etc...
Old Oct 18, 2012 | 09:37 AM
aMsupp's Avatar
C300 Sport
Measure an inch from where they're sitting now and physically see where they'll land. My guess is it will be close to "flush" on the fronts. Then your rears will be way tucked unless you add a large spacer (around 50 mm - 25 mm for getting that inch back from dropping wheel size and then another 25 mm to match the inch gained up front).
Old Oct 18, 2012 | 01:59 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
... 3. Without spacers, the car will have ridiculously tucked rear tires and will look like a mexican show car without a dropped suspension. AKA
Just my .02!
Actually,
1) the front and rear oem staggered wheels have different offsets
2) the hub face separation, F & R, is the same as the C300 Lux model with 4 identical wheels.
3) the oem rear wheel offset puts all the extra tire width inboard, so the staggered setup has the same position of the wheel face, relative to the fender, as the non-staggered version.
4) 4 same wheels will NOT look wierd in the back.
Old Oct 18, 2012 | 02:11 PM
kevink2's Avatar
NO. see my reply above.
What you need to find out is what the offset is for the new wheels.
Here is all the specs for W204 oem wheels:2008 OEM Wheels & Tires
Old Oct 18, 2012 | 02:27 PM
finger360's Avatar
2016 C63s AMG
Yea, the grade of fuel doesn't necessarily mean quality; the main difference in the grades is the compression which the fuel ignites properly under. Higher grades combust at higher pressures is all. Hope this helps.
Also, yea I recently purchased a C300 too; my biggest gripe is knowing that the wheels are different sizes so I don't know what to do as far as rotating tires. I guess we just don't do that?
Old Oct 18, 2012 | 04:41 PM
aMsupp's Avatar
C300 Sport
Like a newb, I forgot about mentioning this before posting. Like he said, you need the offset on your new wheels, then do math by knowing the offset of your current wheels and figure out how to space them. Also didn't realize the rears were 8.5s - I don't know why I thought they were 9.5s... brain fart. The rears won't look too tucked at all.
Thanks for correcting my bad info kevink2.
Old Oct 18, 2012 | 06:46 PM
white46's Avatar
08 C300
Just my .02!
I will not carry on with regular-premium debate. As for traction, we are comparing between 225 vs 245 tires with about or less than 200lb. Realistically it won't make much difference on regular driving. Maybe has little effect on auto-cross session or track days. But then, if the OP is considering about these events, he won't be asking these questions either.
As for spacers, like you said, are for looks only. Generally speaking, on staggered setup, front wheels have lower offset than rear. So if you install front wheels on rear, due to lower offset, the wheels aren't tucked as bad.
Old Oct 18, 2012 | 07:34 PM
smileyworm's Avatar
C300
The car is getting painted before I pick it up and I took a peek at the tires. 225 in front and 245 in the rear.
Old Oct 18, 2012 | 11:09 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Hello everyone!
Stock wheels if 18" are 8" in front & 8.5 in back.
Old Oct 18, 2012 | 11:11 PM
RLE's Avatar
RLE
Sure we do. Swap left to right and right to left, assuming they are not directional.
Old Oct 19, 2012 | 06:29 PM
kevink2's Avatar
The math most likely is not needed. Simply put, the distance between front hub faces, is the same for the common wheeled Lux models AND the Sport versions with staggered wheels. The same is true for the rear hub separation.
So if you buy 4 identical wheel/tire pairs, and the the tire and wheel are like stock C300 fronts, 225/45-17 tires and 47mm offset wheels, the look and exact dimensions will be identical to a stock Lux model.
It just goes back to historic info on what wheel offset and tire size fits.
Old Oct 21, 2012 | 12:11 AM
smileyworm's Avatar
C300
I have ordered falken 7m wheels. They are 18 inch and 8 inch deep. They are telling me that I will not notice the difference between the front and back regarding the depth. Are they blowing smoke? My stock are 7.5 in the front and 8.5 in the rear
Old Oct 21, 2012 | 11:21 AM
Sportstick's Avatar
Another round of ICE
8" wheels replacing 7.5 in front and 8.5 in rear works fine. Search for my thread on Powerwheels Pro AMG reps. I'm working with 17s, but the idea is the same. I actually kept staggered tires on 8" wheels all around, which also fit perfectly. Three years later, and doing fine. Check the photos in the thread.
Old Oct 21, 2012 | 12:30 PM
kevink2's Avatar
Re-read my post #12, read item 4) several times
Old Oct 22, 2012 | 10:00 PM
DonjuanOriginal's Avatar
2008 C300 6speed, 2015 GLK 250 2017 E400 wagon
[QUOTE=finger360;5399229]Yea, the grade of fuel doesn't necessarily mean quality; the main difference in the grades is the compression which the fuel ignites properly under. Higher grades combust at higher pressures is all. Hope this helps.
sorry to high jack this tread. But your right grade doesn't always mean quality. Gas price dropped in toronto recently so i treated the benz with some 94 octane. Horrible fuel economy I got on this tank. you just never know what fuel quality your getting these days. But OP use 91 or higher. always. good luck with your wheels and tires.
Old Oct 23, 2012 | 01:48 PM
Matt_Eurojerks's Avatar
w204 C300
Look at the offset calculator in my signature. Then go measure on your car. When you see the actual difference you will be relieved.
