C300 stock wheels no longer fitting, grinding sound
Old Dec 3, 2012 | 05:49 PM
Stacherson's Avatar
C300
I have a 09 C300 that I am recently taking back to stock. Originally I had after market rims/tires and suspension. I went to put the stock wheels back on last night and came across a problem. The wheels are in the right position as far as 245/40 in the rear 225/40 in the front but I can hear something grinding when it rolls. Almost as if I need a spacer? A little confused as these are my original stock wheels. Anyone else ever had the same problem? Or know what I'm doing wrong??
Old Dec 4, 2012 | 12:43 AM
mangoango's Avatar
08 C350
Did you use the same lug bolts that were used with the aftermarket wheels? Maybe they're longer than the stock lug bolts?
Old Dec 4, 2012 | 02:49 AM
Stacherson's Avatar
C300
first thing I thought too, i've tried both just to be certain
I'm stumped. Only thing I can think of is that I left these stock wheels (w/lugs) at a buddies shop. I'm wondering if they are lugs off of another mercedes...would that even make a difference?
Old Dec 4, 2012 | 08:26 AM
Glyn M Ruck's Avatar
Super Moderator
If your rear lug bolts are too long they foul the e brake mechanism in the rear wheel hats.
Old Dec 6, 2012 | 01:23 PM
BEEPbeepZIPtang's Avatar
w204
bolts should be 14mm X 1.5 X 1.1" (27mm) for regular C-Class. R14 ball seated. this is 100% correct. just done yesterday (12.5.12). Pep boys carries them for about 25 bucks, the dealership charges 125...typical.
if you use lugs that are even a few mm's too long you will destroy your ebrake within a few miles at high speeds.
Old Mar 19, 2013 | 05:35 AM
Stacherson's Avatar
C300
got the original wheel studs from the dealer problem fixed thanks for the help guys
Old Mar 19, 2013 | 07:58 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
How do you know all this, like an automotive encyclopedia!!!
Old Mar 3, 2014 | 12:19 AM
Jpslikk's Avatar
C300
This happened to me too but only on the aftermarket wheels. Wat causes it? Is it too long??
Old Mar 3, 2014 | 01:24 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Yes long bolts. Same thing happened on mine good thing nothing got messed up.
Old Mar 3, 2014 | 01:41 PM
Akhafeez's Avatar
2004 C240 4matic, 2009 C300 4Matic
I had the same issue and just shaved mine down.
Old Mar 11, 2014 | 07:45 AM
Jpslikk's Avatar
C300
@shotgun I took the bolt out and the tip look like there were no contact against the break at all still look new
