How to Remove Shark Fin Antenna
Old May 16, 2013 | 06:03 PM
JPetros2008's Avatar
2016 AMG GTS
Hey guys. Tried searching, but couldn't get a solid answer. Going to wrap my roof and wanted to know if someone could please help me figure out how to take the shark fin antenna off the roof? Not sure if it just pops off or if I've got to go in from under the car somehow. Any help would be appreciated. Thanks!
Old May 16, 2013 | 07:25 PM
Mixedfruits's Avatar
E63 Black on Black
there are screw under the fin take off your rear dome light, but you need some long tools hard to get there
Old May 17, 2013 | 12:47 AM
C300S 6MT's Avatar
C300, 330i, MDX
if u decide not to take it off, start from the back and slit open on top of that antenna...
Old May 17, 2013 | 10:20 AM
2016 AMG GTS
i figured out how to reach the screw underneath, but someone told me that i can't disconnect the actual shark fin from there since there is wiring attached to it. this will help allow me to wrap the roof correctly, but i also wanted to paint it black to match the roof so that will become a little more difficult.
can anyone confirm that it's not possible to detach the antenna without taking the roof liner out from the inside of the car?
Old Aug 22, 2013 | 12:35 AM
belarus27's Avatar
2010 e550 p2
how did everything worked out for you ??? any luck? im trying to remove it on w212 cant seem to find any solid answer
Old Aug 22, 2013 | 01:55 AM
vic viper's Avatar
S213
You can pull it off without accessing it from the inside but you will brake it and need to replace it, and when mounting you need to take down the head liner anyways.
Old Aug 22, 2013 | 04:04 AM
belarus27's Avatar
2010 e550 p2
So best way is to take down the rear head liner where lights at , and unscrew it from there.
What about wires running to antenna? Are they pl7g n play ones.
Thank you for your input!!
Old Aug 22, 2013 | 04:45 AM
vic viper's Avatar
S213
Depends on the options on your car, If you dont have GPS, comfort telephony or Satellite radio then you dont have any wires at all, but if you do they are easily disconnected just under the shark fin.
Old Oct 9, 2013 | 01:45 PM
dolvio's Avatar
2010 C250 4Matic
My shark fin seal was damaged (long story). The dealer told the entire headliner has to come down and may not be as good as original when put back up. Is it possible to access from the read dome light?
Thanks,
Adam
Old Oct 9, 2013 | 01:48 PM
belarus27's Avatar
2010 e550 p2
[QUOTE=dolvio;5804818]My shark fin seal was damaged (long story). The dealer told the entire headliner has to come down and may not be as good as original when put back up. Is it possible to access from the read dome light?
I think you just have to remove the rear part of the headliner not the whole thing. Unscrew a bolt n there you go...
Old Oct 9, 2013 | 01:50 PM
dolvio's Avatar
2010 C250 4Matic
[QUOTE=belarus27;5804823]
The story is I was having my roof wrapped in Vinyl. The didnt open my sunroof and cut the seal on the sunroof. It's at Mercedes now gettign fixed. Unbelievable. Looks like they cut the rear fin seal too. I need to be clear on this because MB says the whole thing needs to be dropped.
Old Oct 9, 2013 | 01:52 PM
Diesel Benz's Avatar
Thanks,
Adam
I have not looked at it myself but I remember a friend of mine explained he could fix the antenna from the rear dome light hole but it was not easy. Or was it so that the screw had to come off first before the old part could be removed and the new part can be just pressed in place. If you already have the new antenna, you can see if it can be inserted with the fixing screw in place and tightened. The point anyway is that the headliner was not removed.
Old Oct 9, 2013 | 04:34 PM
dolvio's Avatar
2010 C250 4Matic
Thanks. It looks like the seal should be fine. I had the dealer check it and they do not recommend replacement. 5 hour job is the quote and they remove the headliner. They have done a few in the past and this is their process. But I am leaving it.
Thanks!
Old Mar 11, 2015 | 09:46 PM
FFM's Avatar
FFM
Audi R8
Has anyone figured out how to remove the shark fin without dropping the entire headliner?
Vinyl shop recommends taking them off to wrap the roof.
Old Mar 12, 2015 | 02:10 AM
tejgambhir's Avatar
2012 C200 Sedan
I had my roof wrapped (non sunroof) they just tucked the wrap under the rubber seal around the fin and left a small slit at the back, doesn't really bother me. But yes, won't be perfect unless you can get it off. Too much hassle for me.
Old Mar 12, 2015 | 08:57 AM
FFM's Avatar
FFM
Audi R8
I already had one failed wrap attempt, so am going to another shop and they recommend removing them. I don't want a half assed job done on a brand new car. Next step would be to have the roof painted, which also requires removing it so needs to come off somehow
Old Mar 12, 2015 | 07:22 PM
aznmode's Avatar
2010 c300
Don Nguyen from this forum did the same on mine. I can't tell the difference. But my silver antenna is sometime an eye sore. I wanted to remove and plasti dip it but yea, seems too much of a hassle to remove so I just left it the way it is.
Old Mar 12, 2015 | 08:12 PM
FFM's Avatar
FFM
Audi R8
Damn, guess I'll let the shop know and see how they want to approach it.
Wonder if there's anything special about the wiring I could cut it and just solder it back together afterwards.
Old Mar 12, 2015 | 08:21 PM
Rickelsbk's Avatar
2002 Benz s430
I have a problem with my s550
hi guys can you help me out my Mercedes s550 The other day I was driving and a battery appeared on my dash. Five minutes later on the radio it said shut the car down then the ABS light came on just turned it off turned it back on it was good for a Nother hour now what😢😢😢😢
Old Mar 12, 2015 | 08:30 PM
aznmode's Avatar
2010 c300
This might help.
https://mbworld.org/forums/c-class-w...n-antenna.html
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
