Has anyone done the coil overs personally?
Are there any DIY guides here? How many people have installed a set themselves? How hard was it, and were there any special tools needed?
I found a great price on a set from a member here, but I like to do things myself.
Anyone chime in?
I highly recommend a impact to get the top hat on and off. hex socket to get the front sway bar link off and a lot of patience.
The two lower screws comes of with a 11mm hex.
The front is very easy but the rears arnt that fun, I didnt like that adjustable spring kit and went with adjusting rear hight using shortened H&R springs and different rubber pads instead.
The rears were a pain huh? Did you need a new camber kit to get the alignment back to OEM spec? Also, what was wrong with the adjustable spring kit?
Didnt like the kite due to its very unstable design, the adjuster is bolted down in the lower arm and the spring sits on it on an angle that seems wrong.
