I want to buy a250 18” amg oem wheel
Old Aug 16, 2013 | 07:53 AM
hoho16's Avatar
W204
Is it fit for w204 and good looking?
Old Aug 16, 2013 | 07:55 AM
hoho16's Avatar
W204
http://www.speedmonkey.co.uk/2013/01...-a250-amg.html
This one
Old Aug 16, 2013 | 08:46 AM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Size (inch): 18
Offset (ET): 48
Width (inch): 8
Tyre size: 235/40/18 All corners
These are the probably acceptable but it is a very conservative setup...
If you are looking at something that has a more or less stock apperance I would probably for one, use bigger tires on the back and probably a spacer on the front
BUT I'M NOT 100% SURE. I will do the math later and get back to you.
Old Aug 16, 2013 | 09:13 AM
hoho16's Avatar
W204
Thanks,i can’t found any photo or information,is that not good idea?
Old Aug 16, 2013 | 09:23 AM
hoho16's Avatar
W204
On the other side ,how about the e class w212amg oem wheel,245/40R18 ET48,8.5x18,265/35R18 ET54,9x18
Old Aug 16, 2013 | 10:20 AM
The rims should be fine on that one but I don't know about the tires... Somebody with a little more experience at it should be able to help.
I will do the math on both now in an hour or so I am just going to lunch here now and it has been half a slow day so I will have time at work
Old Aug 17, 2013 | 06:03 AM
hoho16's Avatar
W204
Let me to try this frist.haha
Old Aug 17, 2013 | 06:55 PM
Matt-erhorn's Avatar
2015 C250 Coupe
It will fit fine, I have the MB two tone wheels for the W212 on my car and they fit fine with no rub.
Old Aug 21, 2013 | 07:09 AM
hoho16's Avatar
W204
http://s206.photobucket.com/user/jazzgd1_photo/media/20130821_165815.jpg.html
goodlooking?
Old Aug 21, 2013 | 07:12 AM
hoho16's Avatar
W204
Old Aug 21, 2013 | 09:55 PM
YES I like them a lot
Old Aug 22, 2013 | 04:24 AM
hoho16's Avatar
W204
I'm afraid to see than a250
Old May 9, 2014 | 04:05 AM
Aaronulang's Avatar
Clk 280
A250 oem 18 inch rims to 2006 clk280
Hi mb team, would like to ask your help as i am very desperate now since i changed my stock rims to the a250 oem rims and after the balancing and alignment, i still get a bumpy somehow wavy ride. I put some standard spacers as it is rubbing in front and the ebreak pin is getting hit at the back with the bolt. The ride is so annoying and i dont know what to do next. Tire size is 225 40 18 front and 245 40 18 rear. Attached is a pic of the car and rims and i desperately hope someone could help me. Thanks in advance.
Old May 22, 2014 | 02:32 PM
SilverCLK's Avatar
what is the rim width, offset and spacers front and back?
Old May 23, 2014 | 12:47 AM
Aaronulang's Avatar
Clk 280
Sorry silverclk. Dont know the rim width. But my spacer is 10mm universal fit in front and 30mm at the back. The only thing i know is without the front spacers, the rim itself touches my shocks.
Old May 23, 2014 | 11:52 AM
xaran's Avatar
2012 C 250 Sport Sedan
If your running the tire size 225 40 18 front and 245 40 18 rear you have different overall diameters which will make a change to the way the car drives. Stock sizes for the 18" is 225-40-18 fnt and 245-35-18 rear. When you go wider you need to go with a lower aspect ratio sidewall to maintain the same diameter.
Also sounds like the rims are not correct for your car, if they require a spacer to not hit the front shock they are either too wide or dont have the correct offset or both.
Both of these can cause you ride and handling problems.
IMO take them off and get a correctly sized set of wheels and tires. Im running 18" aftermarket tires and TSW wheels that are front 225 -40-18 on a rim that is 8.5 wide and 48 off set and rear is 245-35-18 on a rim that is 9.5 wide and 54 off set. I believe that is almost exactly what the OEM 18" AMG wheels are spec too
