Has anyone drifted there W204?
with my bilstein suspension its a bit better but still the W204 has a way of wobbling when coming out of a drift.
snow or wet roads make it easy but might give you false confidence to try when its dry
if you however try to make an agressive drift its much less controllable then a BMW.
i had enough confidence i myself to drive around with the traction control turned off and go make slides up intill i ended in the grass next to the road.
if i hadn't had all the space i could have wrecked the merc.
just beware that the C might be easy to control on one slide but when crossing its limit line you might end up in a car that wants to kill you
the car is not designed as drift car
The Benz is actually a safer car than a BMW (not talking M Series). Benz cars are terminal understeerers by design. BMW's go into snap oversteer at the limit that can be hell to control for Mr Average. BMW's generally have greater rear adhesion but when they let go they can be really nasty.
With my current setup of Eibach antisway bars, Bilstein B6, SMERC strut tower brace, my car is just a smidge toward the oversteering side of neutral, and is quite predictable and fun in tight corners with a little throttle lift just to help line up the exit. However, I would never drift it...seems quite abusive to me.
Your 77 3 series had semi trailing arm rear suspension and suffered from chassis floppiness (lack of rigidity) which made the car more prone to snap/throttle lift over steer. Seems like a combination of refinement of the design and a more rigid chassis made it work well in the e30's, particularly the e30 M3.
The tendency to oversteer is part of the BMW driving feel & is fun until you lose the plot. More BMW's are written off due to this tendency in the hands of less than capable drivers than any other cause.
