Newbie -is oil grade critical? n owners manual
Old Feb 3, 2014 | 12:30 PM
apollo77's Avatar
2008 C300 Avantgarde S - 1971 Jensen Healey - Toyota Hilux-
Hi.. two questions. First up have recently bought a 2008 C300- 7sp Auto avantgarde S-with 45k-ex Japan- the car sales did a oil change before I bought the car but they used 5w-30 synthetic oil and not the 0w-40 that is supposed to be used.. should I wait till next service after 15k to get the correct oil put in or get it changed now?.. NEXT my VIN WDD204054-2A212939 with no owners manual- where can I download one.. the ones i have seen are all different to mine? Thanks in advance for your help..
Old Feb 3, 2014 | 06:48 PM
Glyn M Ruck's Avatar
Super Moderator
This is all that's easily available.
http://www.mbusa.com/vcm/MB/DigitalA...350sport_1.pdf
5W-30 is OK but is it a Benz approved product?
If oil unknown run it 7500Km & dump it for an approved 0W-40. Don't change filter & then get into your standard change pattern at 15,000Km intervals.
Old Feb 3, 2014 | 07:16 PM
apollo77's Avatar
Thanks..
Old Feb 3, 2014 | 08:29 PM
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
Oil grade is not critical. Carrying an MB 229.5 spec approval is, as Glyn noted. Which 5w-30 oil did they use?
Old Feb 4, 2014 | 03:32 AM
apollo77's Avatar
Not sure as cant be positive that the oil sticker is actually the oil that was used- will email them and get back to you..
Old Feb 4, 2014 | 05:42 PM
apollo77's Avatar
Its a Aussie oil -Gulf Western did a search and they say it is certified for MB229.51.. so looks OK ?
www.gulfwestern.com.au/.../Euro%20En
Old Feb 4, 2014 | 05:57 PM
Super Moderator
No it's not OK. 229.51 is for Benz passenger car diesel with Cat & particulate filter. Change the oil. This is a low ash oil ~ i.e. lower additive treat.
If it was a decent synthetic for petrol engines but not 229.5 I would have halved the drain.
Old Feb 4, 2014 | 06:13 PM
apollo77's Avatar
Got the right answer.. thanks..
Old Feb 4, 2014 | 06:33 PM
apollo77's Avatar
Filter as well?
Old Feb 4, 2014 | 10:36 PM
Super Moderator
Filter not critical. Run it until your standard 15K service if new.
Old Feb 4, 2014 | 11:01 PM
Pete7874's Avatar
I'd run half the recommended interval with 229.51 oil in a gasoline engine. It's somewhat gasoline quality dependent, too. Low quality gas with high sulfur and ethanol content (like we have here in the US) will cause oil to degrade faster.
Old Feb 5, 2014 | 08:09 AM
Super Moderator
The trouble with the low SAPs products is they compromise cam & tappet protection for the sake of the emissions system.
With a diesel this is OK because they are rev limited by the combustion process & don't run aggressive cams. HTHS is also less critical.
I would halve the drain with a 229.3 type of product.
Old Feb 5, 2014 | 08:53 AM
Pete7874's Avatar
When you look at the testing specifications of 229.5 and 229.51, they both have the exact same cam, tappet, piston, bearing wear limits. What makes you believe that 229.51 provides less protection?
IMO, it provides the same protection, but just for a shorter interval.
Old Feb 5, 2014 | 09:03 AM
Super Moderator
Not so. 229.51 is deficient out of the gate for Benz gasoline engines. The very reason that Benz decreed that no one product could claim meeting both 229.5 & 229.51 & imposed the ash clamping limits.
We have thousand of hours of testing in our labs proving this. Unfortunately it is proprietary so I can't share.
The trouble with the cam & tappet area is once microscopic flat spots develop on the cam lobe you have a clattery engine. This can't be reversed.
Old Feb 5, 2014 | 09:25 AM
Pete7874's Avatar
Very interesting. How long ago did you carry out these tests? FYI, the performance parameters of all MB specs were recently revised (2012/2013 I believe).
I am surprised you'd take 229.3 oil over a 229.51 oil. The 229.3 spec has less stringent wear limits.
Old Feb 5, 2014 | 09:30 AM
Super Moderator
The 229.3 Products are optimised for gasoline performance. The 229.51 for diesel performance. Testing is ongoing & current.
Old Feb 5, 2014 | 11:25 AM
Super Moderator
To make this a little more easily understandable.
Diesel formulations have to combat high temperature sludge while gasoline formulation chemistry concentrates on low temperature sludge etc.etc. as an example.
When formulating a premium high performance & relatively high margin product like 229.5 you look after Benz while capturing, VW, Porsche, BMW, Audi & others in the net. While net additive treat cost (NATC) is watched with no ash limit to contend with you actually have quite a lot of quality give away due to high additive treat rates & you exceed many specs by quite a considerable margin.
When you formulate a low SAPs product with in the case of 229.51 an ash clamping limit of 0.8% & ACEA & API trying to clamp Phosphorus & Zinc on certain grades you end up with nowhere to go. While ashless dispersants etc. are available there are limitations. You are forced into a fine balancing act due to restricted component treat levels as a result of the max ash. So you end up with a product with no quality give away that just meets all specs but certainly does not exceed them. Therein lies the compromise of giving away some engine protection for the sake of protecting the emissions system.
Old Feb 5, 2014 | 12:24 PM
Pete7874's Avatar
Thanks, Glyn. That's what I thought. But in real world, is the difference between an oil that just meets the spec and one that exceeds it all that noticeable to an average Joe and his engine? These specs appear to be fairly stringent to begin with. MB 229.5 and 229.51 are some of the most stringent passenger car mfg specs in existence today. Are we talking here about engines dying prematurely before they hit 200K miles as a result of running an oil that only meets the spec but does not exceed it?
Not trying to doubt what you're saying. Just want to better understand the real world implications.
Old Feb 5, 2014 | 06:33 PM
Super Moderator
In the real world the differences become apparent as mileage rises on a runaway curve. At 60K miles as an example while the differences would be measurable both engines would still be OK. At 120K miles the differences would be marked. By 200K miles the engine running on the better product would show minimal wear & have good further life expectancy while the engine run on the inferior product would likely be a clattery oil burner assuming equivalent service interval & all things remaining equal. Obviously this scale slides up or down on severity of use.
In town vehicles that incur a lot of stop start running & running at less than ideal fuel trim and not fully warmed up for a large percentage of their life display wear earlier as do engines that get hammered when cold & clearances have not normalised.
I come from a country that has large life expectancy from Benz products. Our company as an example always use E Class models as company taxis to run execs to & from home & the office and airport etc. These things get up to 700,000Kms in a heartbeat & completely trouble free because they are serviced to the book & run on premium products.
A friend runs an airport taxi fleet of Benzes in KL Malaysia. He has run many of his cars to over a million Km's serviced by Cycle & Carriage ~ The Benz agents. As Gan always says. One hell of a lot of tyres & brake pads but no mechanical failures.
Old Feb 5, 2014 | 06:45 PM
Pete7874's Avatar
Thanks, Glyn. I had no idea.
Old Feb 5, 2014 | 10:31 PM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Agree in principle. Here in OZ any taxi; Toyota, Mitsi, Chev, Hyundai etc reg get in excess of 1 million kilometers, with out touching the motor. More to do with the fact the engine is never cold, cold starts are where 90% of engine wear occurs.
Old Feb 6, 2014 | 09:45 AM
Super Moderator
Having lived in Aus & experienced your Taxi's I can vouch for what you say. Ford & Holden transmissions just get bloody noisy.
The lesson here however is that Benz does not want to see low additive treat 229.51 Diesel engine oils in it's gasoline engines. And for good reason.
