Waterless coolants?
- Water is considered an impurity and before installing Evans Coolant, most of the water must be removed from the cooling system.
- For a successful conversion water content must be below 3%. In order to take advantage of Evans Waterless coolant, water content should be checked periodically & maintained below 3%.
- Evans Coolant is maintenance free for the life of the engine. Do not add water in any situation.
Their only real benefit is higher boiling point & close to zero evapouration. In a closed, well controlled system with excess cooling capacity like a Benz this is moot.
ˈeləmənt/
noun
noun: element; plural noun: elements; noun: chemical element; plural noun: chemical elements
1.
a part or aspect of something abstract, esp. one that is essential or characteristic.
I am not referring to the elements of the periodic table, but as the definition states, water being a part or aspect of something. H20 itself is not an element, but a substance or a compound.
