New facelift style OEM look aftermarket tail light for 2008-2014
Old Feb 26, 2014 | 11:37 PM
snowmuch's Avatar
C63 AMG
Holy crap, it looks just like OEM, this is great alternative for MY10 and MY11 who can't reprogram their SAM.
Old Feb 26, 2014 | 11:42 PM
robnyc's Avatar
X4M, G80 M3
Wow! Thanks for the update and hopefully the load resistor will remove the errors and light them up correctly!
I almost bought smoked Depos LED one but these new facelift style will go perfect if I decide to buy the facelift aftermarket headlights too
Old Feb 26, 2014 | 11:58 PM
aznmode's Avatar
2010 c300
The funny thing too is that it has German writing on the back.
New facelift style OEM look aftermarket tail light for 2008-2014-20140226_200829_zpsq3ao3eih.jpg
Old Feb 27, 2014 | 03:01 AM
teja1936's Avatar
2010 Calcite C300 with AMG Sports Package
Not one to poo poo everyones hopes, but has any one even considered that these tail lights may in fact be OEM face lift lights and the seller has just bought a heap of them on the cheap from an ebay seller in Germany (if you look on the German ebay site thare are quite a few) and is flogging them off but still making a buck or two, given that there won't be much of a market when the new w205 hits the market. All the issues that are surfacing with these tail lights are identical issues that forum members are experiencing when fitting OEM tail lights purchased either from dealers direct or direct from suppliers in Germany. What do you guys think??
Old Feb 27, 2014 | 09:17 AM
snowmuch's Avatar
C63 AMG
Oem has a Benz logo on the inner corner of the tail lights. Not sure if this one does?
Old Feb 27, 2014 | 09:34 AM
caligreenzzz's Avatar
W204
I wouldn't doubt it, knowing that its not plug n play and selling them as if they where, kinda lame on the sellers side....
Old Feb 27, 2014 | 09:48 AM
  #32
w204_Generic's Avatar
2011 C300 4Matic Sport
I don't think they are. I read into the eBay ad a little and it states that these are OEM style LED tail lights.
Also says that they are made from a certified manufacture.(Not Mercedes-Benz)
Old Feb 27, 2014 | 02:03 PM
  #33
aznmode's Avatar
2010 c300
Ya totally lame. He even put an image of the parking light lit and I don't see the brake light lit whatsoever. To proceed with the brake light resistor mod, I will have to cut 2 wires from the stock harness so I can get the resistor in series. I know how to solder and all that but I'm not sure if I should even attempt to try it and it not work. But at the same time, these tail lights are so much nicer that I kinda want to try it.
Old Feb 27, 2014 | 02:10 PM
  #34
W204
You have nothing to lose, go for it...
Old Feb 27, 2014 | 05:33 PM
  #35
aznmode's Avatar
2010 c300
I have 2 auto shops I'm inquiring with about programming my SAM so I'll be going that route first. Don't have high hopes but worth a try.
Old Mar 4, 2014 | 09:38 PM
  #36
aznmode's Avatar
2010 c300
We tried it but the tech couldn't get into parameters to change it. He's willing to try another 2010 SAM so if you're interested I can give you his info. Really cool dude and very knowledgeable. And if you have a 2009 and you're in the bay area, I gave him the instruction for 2009 that was floating around here. So I'm sure he get yours done. PM me if you have questions.
Old Mar 4, 2014 | 10:06 PM
  #37
Just buy a 2012 facelift used rear-SAM and it will work.
Old Mar 5, 2014 | 12:29 PM
  #38
W204
Old Mar 5, 2014 | 01:29 PM
  #39
And your point of this reply was to?
Old Mar 5, 2014 | 02:35 PM
  #40
W204
That ur reply is already known bro...
Old Mar 5, 2014 | 02:39 PM
  #41
Maybe to you it is , but it was never mentioned in this thread; using a 2012 rear SAM.
Old Mar 5, 2014 | 10:43 PM
  #42
rshah31's Avatar
2010 Arctic White C300 4matic Sport
Well. As I suspected, brake lights are halfway lit and fogs are on. Damn it. Hopefully the guy I know with the daig tool can help. I wonder if the resistor's will do anything. Getting a set so might try one on the parking light.
Bummer. Sorry that it did not work out.
I think these sellers are misrepresenting the fact that these lights are not programmed for 2008-11 models. They are meant to be replacements for 2012+ models.
Other sellers on ebay selling the same lights are using random images of 08-11 models with facelifted tails that have not been programmed. Example:
Old Mar 5, 2014 | 11:28 PM
  #43
robnyc's Avatar
X4M, G80 M3
Did you get these ?
This seller fishcake
http://www.ebay.com/itm/121230610775?item=121230610775&viewitem=&vxp=mtr
This auction is for a BRAND NEW SET (2 Pieces, Left + Right) of
2012+ FACELIFT Style
Red/Clear/Red Rear LIGHT BAR L.E.D Tail Lights
WITH WHITE LED REVERSE LIGHT
for 2008-2011 Mercedes Benz W204 C-Class 4D Sedan
(Will not fit models with Factory Equipped LED Tail Lights)
* Brand NEW Set (2 pieces) and Never been used
* You might or might not know that Mercedes offers both LED and Non-LED versions of tail lights on the W204 C-CLASS. This is your perfect solution if you have the Non-LED version and want to upgrade to the top of line AMG look LED version. With our new tail light, you know can own the real LED tail light onto your Non-LED C-Class. Not only that, this
* This is the 2012+ Facelift style that has the latest "Light Bar" illumination LEDs. In addition, it includes the White LED for the rear reverse backup light feature.
Old Mar 6, 2014 | 05:43 PM
  #44
aznmode's Avatar
2010 c300
Originally Posted by robnyc
Those are different than what I posted in the OP. They've been selling those for a while now which doesn't look exactly like OEM but they work without any mod or reprogramming. I had them but there was quality issue so I returned them and a few days later found the one I posted. Those also have huge resistors on them so if you do end up getting them make sure you keep those resistors away from plastic of fabric as they get hot. If possible, mount them on metal so the metal can absorb some of the heat.
Old Mar 6, 2014 | 05:45 PM
  #45
aznmode's Avatar
2010 c300
Total misrepresentation. And yea they've been popping up all over now and I noticed some of them use mbworld members images. Atleast the one you posted has the picture half right (left side), even though that image is from another member here.
Old Mar 7, 2014 | 12:41 AM
  #46
mbtran's Avatar
c300
Hi Aznmode,
I just purchased a pair as well. Do you have any updates after load resistor? is it still half illuminate like in your pics? how would you fix this?
thanks
Old Mar 7, 2014 | 09:43 AM
  #47
W204
Originally Posted by mbtran
Hi Aznmode,
thanks
There's only two ways, reprogram ur rear sam or buy a 2012 rear Sam.....goodluck
Old Mar 7, 2014 | 03:32 PM
  #48
aznmode's Avatar
2010 c300
Hi Aznmode,
thanks
I haven't installed the resistors yet since I'm not sure if it's the correct OHMs..and also I haven't had much time this week. Our work is moving so my projects are in the back burner at the moment. I'm hoping there's an easy way to test without hacking into my wires but hopefully this weekend I'll find out. Another thing that sucks is I don't really have a garage to work in so to be able to see if the mod works, I need to work on it after sunset.
Old Mar 7, 2014 | 04:44 PM
  #49
Your post is already known.....
Old Mar 7, 2014 | 06:51 PM
  #50
W204
Like u being a troll...already known....
