Brake Pads C200K
Old May 1, 2014 | 11:21 PM
Sentosa's Avatar
C200 Estate Kompressor W204, 2018 GLA 220d
Brake Pads C200K
Just about to change pads up to the Akebono's. What sort of mileage should I expect to get out of an original set of OEM's?
Had the car serviced last month and the report states 2.5mm front and 2mm rear remaining. Looks more like 7mm all round to me. I have 67,000k's up.
Old May 2, 2014 | 11:07 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
It all really depends on your driving....highway, city, or spirited driving will have a direct impact on the mileage to get out of a set of pads.
Old May 2, 2014 | 04:58 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
As Capt. says above , depends on driving conditions.
I have done 83,000 km & calculating wear should get about 250,000 km. Now about 10 mm. Old fart country driving of course.
It may well be worth while removing a couple of wheels to check the wear yourself as 7mm should last quite some time. New are about 13 mm .
Also check your disc thickness . I bought a cheap Chinese brake micrometer. If you achieve longer wear on your pads you may be able to change your disc & pads at the same time. The wear limits on front are 26mm & rear 8.3.mm.
By the way, pad wear indicator actuates at 3mm.
JC
Old May 2, 2014 | 05:37 PM
Sentosa's Avatar
JC
Well, my driving would be about the same as yours. Back and forth to Sydney once a year at high speed when possible on our roads and locally around here.
If the indicator actuates at 3mm then the dealers report is inaccurate. Reason I was asking is that the pedal sometimes goes close to the floor and I feel I have to pump it to get it firm. Also, according to the dealer the system was bled and the fluid was changed. I did check the fluid and it appears to be clean and new.
Old May 2, 2014 | 07:06 PM
Carsy's Avatar
On this forum a year or so ago a South African was having the same problem with his W204 brakes. His pedal went to the floor & it took quite some time for MB to come to the party. They did discuss whether the ABS was the cause.
Glyn Ruck was involved in the discussions .You could contact him if you cannot find the thread.I cannot find it as yet.
Here is another thread which may help.https://mbworld.org/forums/c-class-w...placement.html
Good luck & let us know how you go.
JC
Old May 2, 2014 | 07:10 PM
Carsy's Avatar
Sentosa ,Here is Glyns link https://mbworld.org/forums/c-class-w...ys-normal.html
Old May 2, 2014 | 09:04 PM
Sentosa's Avatar
John
Thanks for that, I have read it all but am still not sure if that is my problem. Will go thru it all again. One thing tho is that his problem and mine started after a trip to the dealer to work on the brake system in some way, his for pads mine for a brake bleed. I wonder if it is the same with other cars.
Old May 3, 2014 | 02:44 AM
Carsy's Avatar
Sentosa ,
If the dealer caused the problem then they should fix it free of charge.
Maybe they let a lot of air into the system & another bleed is required.
I have flushed my brake fluid 3 times ( every 2 years) by the pressure method in reservoir & have no problem with having a pedal afterwards.
Old May 3, 2014 | 03:27 AM
Carsy's Avatar
John
Attached is the WIS regarding calculating brake pad wear.
Old May 3, 2014 | 06:21 PM
Sentosa's Avatar
Carsy,
Again, thanks. I will take it for a drive today and see if I can more closely relate it to any of the symptoms in both those threads. I will also determine the amount of actual pad I have left on all four corners..
Unfortunately the dealer that serviced the car is in Sydney and our closest dealership up here is about 30ks away. Problems of leaving in a regional area. However determining the exact problem is what I have to do first. I wonder if anybody else in Australia is experiencing the same problem. Feel free to chime in.
