Who use Vediamo V05.00.05?
Old Oct 27, 2014 | 12:02 AM
Austin2014's Avatar
X5
I start this thread to aim to get some answers:
1) who used and using Vediamo V05.00.05?
2) What can it do and can't do?
3) Where are get best ediamo V05.00.05
Old Feb 25, 2015 | 05:56 AM
valiuskli's Avatar
Bike
hi
If you have some info about Vediamo share please
Old Jun 16, 2016 | 10:50 PM
supra94tt's Avatar
2005 E55, 2000 540 SC 6spd
Nobody so far? I was looking for same info .
Old Jun 16, 2016 | 11:28 PM
xEryx's Avatar
2019 E63s AMG
I use 4.0xxxxxxx
It can do anything that Mercedes Xentry can do, but is more complicated because it pulls from the source which is all German.
It can program pretty much anything on a car.
You need a STAR Diagnostic tool to use Vediamo, doesn't seem like you know much about it so I figured I'd add that.
Old Jun 17, 2016 | 12:06 AM
supra94tt's Avatar
Originally Posted by xEryx
I use 4.0xxxxxxx
That's a lot of assumptions on your part, but anyway, I have Vediamo installed along with Xentry 2016/03, but no manual for it, my C4 multiplexer connects with Vediamo just fine.
Old Jun 17, 2016 | 06:27 AM
xEryx's Avatar
2019 E63s AMG
[QUOTE=supra94tt;6835459]That's a lot of assumptions on your part, but anyway, I have Vediamo installed along with Xentry 2016/03, but no manual for it, my C4 multiplexer connects with Vediamo just fine.
Is not, it was meant for OP. It didn't seem like he knew much about it and he's not the first who has asked about Vediamo without being aware of the Mux part. Anyways, you surely bought it with a purpose so you will need to be more specific with the information you need help with. There are about 5 people here with one as far as I know.
Gorgeous C63 by the way.
Old Jun 17, 2016 | 10:08 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
I use/have vediamo and the required hardware. Like xEryx said, it's similar in purpose to Xentry but can do far more detailed variant coding, without the need to have an online connection to Daimler AG servers for authorization. In Xentry, variant coding is restricted, and even then once authorization is granted, the coding options are limited in comparison to Vediamo.
Spend some time looking around on the internet for a download link for it, you'll also need to have it activated with your hardware ID, etc. I won't post a link, I don't think the software is typically free and I might violate some forum rules by doing so, sorry.
Let me know if you have any specific questions on its use, if you already have it installed and you can connect to to the car with it.
Old Oct 2, 2016 | 10:05 PM
Vladds's Avatar
2010 C63 2019 GLA45
I'm only starting with Mercedes software, but have been quite active with changing calibrations of the ECU with other cars.
Other than module version re-coding, talking about the ECU:
Does Vediamo display the 3D curves off of which the ECU runs the engine?
Does it allow editing?
Here's an example: Maybe I want to change my injectors with higher flow units, does Vediamo open the injector CC rating table to where I can change there the rating to the ones I want to install?
Edit the temperatures at which the ECU turns the fans on?
Fueling and so on.
Does Xsentry, vediamo or DAS log a complete set of parameters?
Old Oct 3, 2016 | 05:35 PM
Funkwagen's Avatar
Fueling and so on.
I wish Vediamo could do fuel mapping. I don't know what program to use for it, if one even exists. As far as I know, the ECU's have to be pulled from the car and bench flashed (with something I know nothing about I guess) to do any kind of fuel map tuning
Old Oct 3, 2016 | 08:26 PM
Vladds's Avatar
2010 C63 2019 GLA45
So let me ask you this then:
In the Mercedes world, is there such thing as tuning the car on the dyno?
Not tune-in-a-can send your ECU and get it back next week, but change calibrations and reflash 5-6 times in a session, or more if necessary, logging the results?
In the Subaru world it is heard of, of tune live too: you change parameters and keep rolling, when you have it right, you reflash.
I mean, I get that the car runs in closed loop probably most of the time and pretty much detects changes, but still......
Anyway, I appreciate the info.
