Maintenance question
I am just curious what are the indications for the W204 that it is time for new spark plugs? I know there is the typical rough idle, hesitating to start, high fuel consumption that people always talk about but if I do not experience that except for the gas consumption (lead foot of mine) how do someone knows when it is time unless the dealer tells you because MB says so.
Is it best to just replace it for peace of mind? btw car is already 7 years old.
I also want to know what you guys think about the transmission and TQ flush. It was done 2x (1 at 60k and 1 at 72k - because I found out they did not do the TQ flush at 60k so I let them redo it because of the knowledge from this forum). I drive the car really aggressive so when do you guys think I need to do the flush again?
It's up to you whether you want to follow to book or not.
Personally, I wouldn't do either.
I understood that the MB transmission oil change interval was 39,000 miles which included the torque converter.
If you drive hard all the more reason to change on time or before.
There are lots of sad stories written on this forum about those who do not follow this recommendation.
Take a look at the "sticky" on servicing atms at the beginning of the 204 section.Your 7 speed is not as robust as the 5 speed.
Regarding plugs it is always wise to do "preventative maintenance" ie to avoid the symptoms of poor spark.
You own a well engineered car, why do not service it as they suggest in most respects.
Edgalang,
Did you see any difference on mileage and how the car runs after replacing the spark plugs on your ride? I watched a youtube video on how to replace the w204 plugs and it is easy and I have the tools but I am just lazy and will let the dealer do it instead.
Edgalang,
As far as performance goes, like I mentioned before, the original plugs I pulled were such in a good condition, I doubt it made any difference replacing them at 60k when I did. That being said, I'm still going to follow the maintenance book moving forward regardless of my observations.
As for the transmission service, I cringe at the sight of someone posting they have not or will not change it at the recommended periods!
My C250 just hit 60k when I changed the plugs; and I did put the anti-seize on the plug threads.
They are roughly $12/each online. (I purchased mine from Amazon).
...and in case anyone has any doubts...
https://content-na.drive.amazonaws.c...mb?viewBox=932
EDIT: This is for M276. Please check to see if they use the same plugs in the M272.
TIPS:
#1 You HAVE to put dielectric grease on or else you'll have a very hard time taking it off afterwards. At the very minimum, smother it on the ceramic part of the plugs.
#2 Do NOT use anti-seize on the plug threads. The threads are already prepped with a coating and it even says to not use anti-seize somewhere on the box.
Also, the threads have anti-seize material on it. So if they're original, it must have been applied from factory. I don't recall the boxes having a notation about not using anti-seize. I've never heard of that, actually. I did my plugs several months ago and used it as well.
The indy shop I use, I sometimes hang out and watch them change plugs and they never use anti-seize. He recommends using NGKs over Bosch or anything else for NA, regular, plain ole' c300/350s. He said he's never seen any real benefit from anything more expensive.
If you get into tuning, supercharging (v8s), or upgrading turbos (c250s), then you'd want to change your plugs for your application.
