C350 sport 2013
Old Dec 19, 2016 | 10:20 PM
benmerc350's Avatar
C350
C350 sport 2013
Can I put 4 tires on that are the same size or do I need to keep the 225/45 18 on front and 255/35 18 on rear?
benefits of same sized tires would help me I think.
Old Dec 20, 2016 | 08:52 AM
xEryx's Avatar
2019 E63s AMG
You cannot and that is the best setup you can have with OEM rims. The reason is because the rear rim is 1 inch wider than the front.
Old Dec 20, 2016 | 10:30 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
^ above. Otherwise you would need new rims as well.
Old Dec 20, 2016 | 10:38 AM
benmerc350's Avatar
C350
what sized rims would anyone recommend for a C class C350 sport?
Old Dec 20, 2016 | 12:04 PM
xEryx's Avatar
2019 E63s AMG
If you want to square up max would be 19x8.5
Old Dec 20, 2016 | 12:13 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Would stay with the 18s for ride comfort. 19s look great. Not a lot of rubber. I like my OEM 18s even though front and back are different sizes.
Old Dec 20, 2016 | 01:27 PM
benmerc350's Avatar
C350
where is a good place to buy a set of C Class 18" wheels?
Old Dec 20, 2016 | 02:14 PM
dieseldoc's Avatar
Wheels America has Refurbished OEM wheels. Look at their website.
Old Dec 20, 2016 | 03:01 PM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
Interesting. At what offset and what tire size?
Old Dec 20, 2016 | 03:05 PM
Atlas Grey's Avatar
2005 Porsche 911, 1991 Jeep Grand Wagoneer, 2012 Mercedes C300 4Matic
Is there a reason you want to change the factory specs? Just wondering. The price difference between tires is not that great and outside of giving you the ability to rotate tires I am not sure why you would do the change.
Old Dec 21, 2016 | 01:06 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Why would you replace the OEM 18s with more 18s? Just to rotate? Get nondirectional tires and rotate side to side.
Old Dec 21, 2016 | 09:55 AM
xEryx's Avatar
2019 E63s AMG
45 offset. I have 235/35 all around but if you are lowered I would say 225/40 all around because front rubs when wheel is turned and you hit a dip
Old Dec 21, 2016 | 03:28 PM
mykthex's Avatar
2013 C350 Coupe
Well I've put square tires (225/45/18) on my staggered wheels. I have a C350 2013 with the 18" AMG wheels package (8 inches wide front and 8.5 rear) and I use these wheels for the winter. The difference between the front and the rear is really barely noticable.
I did that to have the possibility of rotating the tires and also because smaller tires width = better traction on snow.
I'll buy new summer wheels when the winter is over.
Old Dec 21, 2016 | 10:35 PM
xEryx's Avatar
2019 E63s AMG
The fronts are actually 7.5 inches so 1 inch difference from back. This is a really bad idea that could cause the 4Matic/transmission to fail and dealer would not cover it because of the wheel setup.
Old Dec 21, 2016 | 11:35 PM
mykthex's Avatar
2013 C350 Coupe
It can't damage the 4matic. My setup has the same tire diameter as the factory spec and it's the only thing that matters. Only the surface of contact to the road is changed and that's totally okay. By the way I just checked my car manual and it's 8inches and 8.5 for me. Canadian version. I measured them too when I made the switch.
I did ton of researches on that and I'm sure about what I'm doing. Also tons of c350 4matic are on 17" square.
Old Dec 22, 2016 | 08:05 AM
LILBENZ230's Avatar
The split spoke AMG rims on my C350 are 18x8 front, 18x8.5 rear. I think the guy is correct.
Old Dec 22, 2016 | 09:16 AM
mykthex's Avatar
2013 C350 Coupe
Mine are those:
And from the manual:
Old Dec 22, 2016 | 11:01 AM
benmerc350's Avatar
C350
Mine are those:
I have the same
