What motor oil to put? I am confused...
Old Dec 20, 2016 | 11:20 AM
dol4er's Avatar
C204
It is time for an oil change and I am confused what oil type and brand to choose. I read so many different opposing opinions that the more I read the more confused I get.
My car (C250) is running an OEM Mercedes-Benz oil but it is too expensive and I am thinking about switching to a cheaper alternative brand which is 229.5 approved.
I was considering Shell Helix Ultra because the price is good and it is said to be used in Ferrari (I guess it should be good then?). Is Shell Helix Ultra a good oil and which type should I go for 0w-40 or 5w-40? Which is better and is there a noticeable difference which I can sense?
Old Dec 20, 2016 | 11:42 AM
Colin G's Avatar
2008 C-230 4Matic Sport
Both should work but I went with 0W-40 synthetic Mobil 1 Euro car formula since where I buy they don't stock it in 5W-40. I live in a climate where it can be cold in spring and fall so 0W-40 seemed like a good choice. I don't drive my car in winter so 5W-40 would have been good too.
Up here the Mobil 1 goes on sale frequently at my local Canadian Tire and I can get a 4L jug for about $38 CAD which is pretty cheap
Old Dec 20, 2016 | 12:02 PM
xEryx's Avatar
2019 E63s AMG
Mobil 1 0W-40 is the same oil in the Mercedes bottle. It is also extremely cheap in 5Qt at WalMart.
Old Dec 20, 2016 | 02:39 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I have used Shell Helix Ultra 5w-30 in my diesel for many years. One of the largest oil companies in the world .
If you live in Death Valley buy the 5w-40 or Wisconsin the 0w-40. Easy. Or just the cheapest or most accessible.
Old Dec 20, 2016 | 03:47 PM
dol4er's Avatar
C204
Where I live, Mobil 1 can be found everywhere but I am looking for an oil which not only meets but it is approved under the MB 229.5 which seems to be a tough job here - probably because 90% of the cars are diesels or I don't know. There are so many similar but different names of the oils... but in the end all Mobil 1s here are under other MB standards but not the 229.5.
Thanks for the response about the Shell Helix Ultra. I am glad you are satisfied and I will go for it because the price is good. Probably the 5w-40 will be best for me.
Old Dec 20, 2016 | 03:53 PM
Crimzon's Avatar
2010 M_B C300 ... Wife drives a 2007 GL450
Mobil 1 0W40 ... It'll say for European engineered vehicles like Mercedes, Porsche BMW
Old Dec 20, 2016 | 04:01 PM
dol4er's Avatar
C204
Yeah, they all say "For Mercedes, BMW and etc." but if you start looking for MB-Approved 229.5, it becomes harder. There are some oils which state "Meets or exceeds MB 229.5" but according to Daimler, they are not compliant with the standard MB 229.5. It must be "MB-Approved 229.5"...
Old Dec 20, 2016 | 04:33 PM
Colin G's Avatar
List of 229.5 approved oil by MB.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Old Dec 21, 2016 | 09:51 AM
xEryx's Avatar
2019 E63s AMG
We already told you Mobil 1 0W-40 is exactly what Mercedes uses OEM and is on the list, what more is there to find out?
Old Dec 21, 2016 | 02:37 PM
Carsy's Avatar
Dol4er, Fuchs is a good oil also if it is available.http://fuchs-eu.lubricantadvisor.com....aspx?lang=eng
John.
Old Dec 22, 2016 | 03:20 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
snip
Old Dec 22, 2016 | 04:49 PM
dol4er's Avatar
C204
I bought Motul 0w-40 and so far so good. Thanks to anyone who tried to help.
Old Dec 23, 2016 | 09:45 AM
BenzAMX's Avatar
2011 C300 4Matic
I using Amsoil all the way. Its way better than Mobile 1.
Old Dec 23, 2016 | 03:16 PM
dol4er's Avatar
C204
It is strange that my car's oil capacity is 5.5 liters but it took 6 liters and it is still not full but in the middle between MIN and MAX on cold engine. How is this possible? I am confused again...
This is a little worrying... is there a logical explanation?
Old Dec 23, 2016 | 10:40 PM
Crimzon's Avatar
Depending on what model you have you should be closer to 9 quarts ... Mine takes 8.9 quarts and it's a 2010 C300 4MATIC
Old Dec 24, 2016 | 03:51 AM
dol4er's Avatar
C204
Mine is C250, it is a 4 cylinder engine and takes 5.5 liters according to Mercedes (not sure how much it is in quarts) but the engine has taken more than the specification which worries me a bit...
Old Dec 24, 2016 | 05:40 AM
Carsy's Avatar
http://fuchs-eu.lubricantadvisor.com...65da728033048e
5.5 litres seems correct. I question whether you have the correct dip stick. check with your dealer & compare.
Old Dec 24, 2016 | 11:26 AM
Crimzon's Avatar
The manual for mine says 8.9 quarts ... The dipstick reads in the middle of add an full marks
Old Dec 24, 2016 | 11:35 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
You have the M272 V6. The OP has the M271 EVO - it's got a smaller capacity.
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Liter equal 1.057 quarts. Do the calculations.
Old Dec 24, 2016 | 01:17 PM
superangrypenguin's Avatar
A car
Mobil 1 0W40. I've tried several and run several UOAs. The Mobil 1 is the best oil for the money and it's easy to buy.
Old Dec 25, 2016 | 06:16 AM
psaldanha's Avatar
Mercedes C220 AMG Style
Just caution:
i saw on one post about diesel!! If your car is on gas, it must be MB-Approved 229.5 (should be on the bottle).
If your car is on diesel, it should be MB-Approved 229.51!
For reference, my W204 CDI220 2008 i put Motul X-CLEAN+ 5W30 MB-Approved 229.51.
Old Dec 25, 2016 | 01:30 PM
Chastity's Avatar
C300
Mobil 1 - 0W40 - from Walmart. Cheap, order online for in-store pickup.
Old Oct 7, 2023 | 01:26 AM
abnertlapu8@gma's Avatar
Mercedes-Benz M271 engine c20 coupe
Mr
my car is C250 M271 engine. The have just changed the pistons and top gasket. Which oil can you recommend to use. Its on 80000km
Old Oct 7, 2023 | 01:05 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Your engine requires an oil meeting the specifications of Mercedes Benz operating fluids sheet 229.5. They are many. Choose one available in your location from this long list:
https://operatingfluids.mercedes-benz.com/sheet/229.5
