help - glove box opens too low
Accidentally pushed hard on my glove box and the lid opens up really low or sometimes it falls straight down and lid comes off. I found 2 rubber square parts on the ground and assume its from the glove box. Can it be fixed without having to buy a whole new glove box?
For the record, I removed the glove box & found the problem was that the small brass clamp holding the 'eye' in the cord of the "shock absorber" ( damper) had broken thus allowing the glove box lid come down heavily & bypassing the 'retaining clamps'. These clamps had not been damaged.
Unusual for modern motor engineering , the "shock absorber" could be dismantled & repaired.
It consists of a plastic tube containing a spring & plastic follower. I re-attached the cord to the follower with an electrical joiner clamp & all worked perfectly.
Parts cost = Nil. Time = 4 hours .
I remember my damper as being round.
Try looking at these photos from Google . You may find your answer.
https://www.google.com.au/search?q=w...&bih=950&dpr=1
There is more information on https://www.google.com.au/webhp?rlz=...ve+box+removal
Hope this helps.
See attached picture with instructions. Good luck!
Watch this video as reference, it is not for the W204 but the concept is exactly the same.
its called glove compartment buffer stop. a good way to search part names is to save a picture of the part on your pc then go to google search and click search by image. upload your picture and let google find it for your and bobs your uncle
JettaRed (07-15-2024)
