'09 C300 - New Battery installed, experience and cost.
My preferred dealer wanted a whopping $370+tax (figure $390) for this task. There is a point when I just cannot justify the convenience of not having to touch it myself so I decided to tackle this myself and save myself $200.
I hauled myself up to the dealer parts department and got a pretty fair price on the battery ($169+tax - ~$178 including tax), bought a battery terminal brush from Autozone ($4.75) and came home to get to work. It was a comedy of errors to say the least, first I was missing the 10mm box wrench I needed for the terminal nuts so went and spent ~$8 for a replacement box wrench, come back home and start working but realize I can't find my ratchet extension to reach down to the battery hold down bracket, back to Ace hardware for a $7 extension. Good to rock on! Only other hiccup I ran into is I disconnected the battery and the new battery was in the closed trunk. I was able to use the physical key to open up the trunk thankfully after some fiddling with the remote fob.
Process was pretty straight forward and easy, the hardest parts were maneuvering the HVAC plenum back in place and lifting that heavy SOB out of the car. I ended up not needing the battery brush or even the baking soda I bought as there was ZERO corrosion on the terminals and the battery tray was immaculate.
Nothing in my car needed re-programming, I was already planning on having to resync the windows and sunroof but they all worked just fine after the replacement and I had the battery out and disconnected a good 15 minutes. All is well now and she starts just fine now!
So dealer cost (tax estimated) - ~$390
My cost - ~$195
Saving $195 and lets say 1.5 hours of time had I the tools I needed, this consists of trip to dealer to pick up the battery and the trip to go recycle the old battery. Definitely worth the trouble and headache I had to endure.
There's no reason any person capable of physically lifting the battery out couldn't replace it themselves. Not much to it.
$310 is not too terribly bad, yeah they are charging you 1 hour of labor minimum but when you factor in the full service car wash you are paying maybe $100 for the convenience of having to not touch it. My sales guy at Malone's in Marietta recommended RBM but it is just too much of a haul for me.....MB of Buckhead is only 15 minutes away, have not had any issues with them and I can usually get a loaner on my service visits.
Physically identical :
Pulls straight out and lots of room to work :
Drops right in :
disconnect wires
remove and replace battery, recconect
*mercedes*
OK STEP ONE REMOF ZE AIR INSTEAK
