Brake Vacuum Sensor issue
Old Jul 3, 2017 | 10:16 AM
AlvinDj's Avatar
W212 FL E250
Anyone has encountered this as well?
I have been having this particular fault code for awhile now...
Have been googling and checking up on it for some time but unfortunately to no avail...
Ride is a W204 C180 CGI 1.8 Coupe aka C204
Any help would be greatly appreciated!
Old Jul 3, 2017 | 10:25 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Check the wiring to the blue highlighted part (the sensor) if everything seems okay, you'll probably need to replace that sensor. Should be a fairly easy job to do
Old Jul 3, 2017 | 10:28 AM
AlvinDj's Avatar
W212 FL E250
Firstly, thank you so much for your help!
Would like to check if this is a common issue? As I have never come across or heard of such an issue..
If it malfunctions / faulty, what exactly would happen to the car? As I can't really feel what's wrong with it.
Old Jul 3, 2017 | 10:35 AM
Funkwagen's Avatar
I haven't heard about this particular issue before at all, but sensors can go bad randomly all the time.
It seems that cars with equipment code B03 (Eco start/stop) are the ones equipped with a booster vacuum sensor. Have you noticed anything odd with the start/stop system?
Old Jul 3, 2017 | 10:39 AM
AlvinDj's Avatar
W212 FL E250
I doubt my car has a start/stop system as I have not come across any start/stop feature in my car.
And based on the diagram you posted earlier, there isn't any wires or sensors etc, connected directly to the brake booster at all...
Only the brake master cylinder is connected to the booster and a pressure hose, that's all.
Basically, part #70 is totally non-existent on my car
Old Jul 3, 2017 | 05:14 PM
soldr230's Avatar
2012 C250 coupe 2007 ML 350
Pic of brake booster 2012 c250 coupe. The only wires noticable are located on the plastic tank.
Old Jul 4, 2017 | 02:20 AM
AlvinDj's Avatar
W212 FL E250
Yes actually mine looks like the C250 coupe ones..
Anyone has any idea how to rectify this matter?
Old Jul 7, 2017 | 04:03 AM
AlvinDj's Avatar
W212 FL E250
Anyone?
Old Nov 7, 2017 | 05:17 AM
AlvinDj's Avatar
W212 FL E250
Haven't found a solution to this... Anyone with some help here?
