Is there warning signs of impending EIS/ESL failure
I'm unclear if there are signs or indications that a failure is pending. Seems like from what I read, there are symptoms some of the time. I'm fearful of getting stranded and hopefuĺy be able to fix before disaster.
Before it happened to me, I noticed that the sound of the unlocking mechanism became very slow. This was noticeable for 6-10 months before the failure occurred. When they changed the module, the sound was very nice and quick again.
2011 C300 Sport 3.0L V6
Do you mean from the key fob outside of the car or from the locking mechanism inside the car on the door?
I only noticed the ESL(Lock) was slower before, after it was replaced(Did not had a reference, did not know any better). I did noticed the new one faster immediately. If it get slowly slower, I doubt I recognise it next time before the "Sudden Death".
Are you referring to how fast the car started? I’m confused as to what was slower?
I noticed the sound of the little motor in the ESL unit getting more and more faint every time my key was put in before it finally failed. The motor would pull out the ESL bolt slower and more quietly till one day it gave up the ghost.
You can actually replace just the motor in the ESL as a DIY/aftermarket thing, but the dealer only sells the entire unit. If yours hasn't failed, and you replace the motor, it won't require any special programming. Once it fails, it sets theft relevant faults and must be cleared, you can't just put a motor in it then and have it start working again.
Sudden Death
If you insert your key, that recognising sound/happening, was faster after they replaced the ESL, I recognised it immediately, no I did not mean how fast the car start in this case. I was just referring to the mechanical action of the ESL & Key inserted.
OK, the car is not running. I insert the key to start the car. Upon inserting the key is when the reported sound takes place.(the electric motor disengaging the pin). I don't hear that. What am I missing?
If you plan on keeping the car for a while then I would recommend getting an emulator and finiding someone locally that can program it.
https://www.ebay.ca/itm/New-W204-ESL...QAAOSwTuVZpvPt
I strongly recommend everyone with a w204 to get an emulator because those steering locks are **** to fail even new ones. If you live in cold climates that is another big advantage on getting an emulator since the steering locks seem to fail more often in cold weather.
If you know its never been done on you're car and you plan on keeping it or see any signs or strange noise or weaker motor sound from the steering lock, get it done asap because if the steering lock still works, you can remove it, if it fails in the locked posistion, you add about 3hours to the job, you will have to remove the hole steering column and use a grinder to get it off, so get it done before it fails and while it still unlocks.
And the motor fails about 1 out of 3 times, 2 out of the 3 times it a chip on the board inside the module so I wouldn't waste my time replacing the motor because even if its the motor and you replace it.
All good info, thank you. From monitoring this issue on the forum, I have been unable to determine if the later models, especially FL models, are subject to the same rate of failure. Obviously they're newer so not as much data, but does anyone have any (anecdotal) data on MY 2013 or 2014 ESL failure? Do we later-model-year-owners need to be worried?
http://www.ogsmechanics.com/tutorial...-engine-start/
found this, looks like the face lift is better but we'll see with age.
Do your car has a different start/key setup-?
