Android 10.25 Screen Unit
Old 04-30-2019, 04:59 PM
  #326
mbellew937's Avatar
2012 C63 AMG Coupe
Has anybody seen this one?
http://smarty-trend.com/mercedes-ben...head-unit.html
I like the fitment better
Old 04-30-2019, 05:04 PM
  #327
kavik's Avatar
2013 c63
I have what looks to be a slightly different/older version but I am happy with it. It looks very factory but upgrades the look of the car nicely. You can search for some old posts of mine about the install. This unit looks even nicer.
Old 05-02-2019, 04:52 PM
  #328
IDIOFFO's Avatar
2010 E550 P2 / 2003 S430
Hi guys, I just purchased one these android units. I have a factory reverse camera, is there any way to that show on the android screen an not the factory command, thus being able to take advantage of the dynamic lines and the radar sensor graph?
Old 05-02-2019, 08:17 PM
  #329
gtnotoriouz's Avatar
2016 C300 4matic
I'm hoping they upgrade the theme on these things to be like the blue modern theme on the 2019 OEM screens....
Old 05-03-2019, 05:33 AM
  #330
Thabiso@1's Avatar
C200 W204 AMG Spec
Hi Rashawn, i have the same problem. Have you found the solution to this problem?
Old 05-03-2019, 05:36 AM
  #331
Thabiso@1's Avatar
C200 W204 AMG Spec
Hi Derekchichi, I have the same problem. Have you found a solution to this problem?
Old 05-08-2019, 10:17 PM
  #332
tawatts's Avatar
2013 GLK350 4Matic; 2010 Audi A4 Quattro; 2004 Yamaha R1
I just picked up one of these, got it installed, video works fine. No audio yet as I have to take the centre console apart to run the ami cable back to the aux in the back of the centre console.
I'll be damned if I can get the radio to go all of the way back into the dash. I'm sitting out about 3/8", and I just can't get the big plug out of the way enough to get the radio to go all of the way back in. Anyone have any special tricks or suggestions on where to try to jam the plugs/connectors to get that last little bit?
Also, where have people mounted the gps antenna? I have it taped up to the underside of the dash just behind the new display unit. I get ok reception, but it's not stellar.
Old 05-09-2019, 10:33 AM
  #333
IDIOFFO's Avatar
I have been trying to figure out how to get the bug plug out of way so that the radio can fit back in too so far no luck.
I did have the gps antenna the same location you have it but the signal wasn’t that great so I moved the antenna to the A pillar inside the trim, much much better signal.
Quick question can you please take a look at your AC temp display and the outside temp display on the unit and tell me if it accurate with what your car displays? The temperatures my car display VS what’s on the android screen are off, see the picture. Anyone having this issue? An it’s the same issue with the outside temp too
Old 05-18-2019, 07:17 AM
  #334
spadatony's Avatar
Mercedes A45 AMG
Same issue, would love a way to fix this.
Old 05-18-2019, 07:40 AM
  #335
tawatts's Avatar
Ok, finally got the head unit fully installed back into the dash. Getting the big plug out of the way so that the head unit will fully seat back in ... not gonna lie ... is a pain in the a... But ... it is possible. I'm installing into a 2013 GLK350, so obviously different that your car, but for me I had to get the big square plug completely below the radio unit and behind the temperature controls before the radio unit would fully seat back into place. Once I figured out that it had to be out of the way, it didn't take me too long to get it there.
Temperature ... same same ... provides a xx.x temperature (why does someone need to know to a decimal point what the temperature is I don't know ... lol) it's close enough for me.
Last problem I am struggling with is that I have no audio coming from the unit. The instructions only came with chinese ... so, I've been taking photos of the manual, then using an app on my iPhone to translate the chinese characters ...
My cable is meant to plug a 3.5mm jack into the AMI unit and then that is how the audio gets into the factory audio ... but nothing ...
Old 05-19-2019, 03:08 PM
  #336
srdjan's Avatar
w204
looks amazing did you try it? or anyone else?
Old 05-19-2019, 08:12 PM
  #337
dsenela's Avatar
2008 C300 4MATIC SPORT
V1 firmware flash
Hi guys,
So I have had the v1 of this unit for the past 2 years. It has been working flawlessly. Yesterday it started acting out, could not boot past the Mercedes Benz logo screen (see attached photo), reverse camera still works as I get an image. I am pretty sure it is corrupted firmware (i have tried resetting with reset button, no dice). I happen to have the firmware, my question is does anyone know how to force firmware flash at boot? I read somewhere to copy firmware on SD card and boot with SD card inserted while pressing reset button, this doesn't seem to work for me. Any help would be highly appreciated I am tired of driving with logo constantly displayed.
Old 05-19-2019, 08:52 PM
  #338
tawatts's Avatar
Applying the firmware / OS to one of these devices is not difficult, but is not for most people.
I have a different brand of one of these in my Audi, and the company just released updated firmware running on Android 7. The approach should be very similar. I can send the link to their wiki, but do not use any of their firmware files … but you can use the instructions to follow how to recover the device. (this is also how you would recover a bricked device)...
dsenela (05-19-2019)
Old 05-19-2019, 08:55 PM
  #339
tawatts's Avatar
Anyone have problems with noise? Audio coming out of the device is great as long as the key is not in the run position. Once there is data going through the CANBUS, I have awful noise in the system.
The unit I have plugs into the 3.5mm aux in jack in the centre console to inject audio into the factory system.
Old 05-19-2019, 09:41 PM
  #340
dsenela's Avatar
Could you please send me the link to that wiki? I am really desperate at this point.
Thanks!
Old 05-19-2019, 09:49 PM
  #341
tawatts's Avatar
Thanks!
Just sent the link. Hope it helps you recover the unit.
Old 05-19-2019, 09:51 PM
  #342
dsenela's Avatar
Thanks!
Old 05-27-2019, 12:22 AM
  #343
PASHN8's Avatar
'08 C63 AMG
Excellent thread having just read through the whole thing, this community is great!
I'm wanting to purchase one of these screen for my '08 C63 AMG in RHD (Australia). Having read so many variances of success and options can anyone recommmend the best and least 'buggy' version out now?
I mainly would like to use carplay, music streaming/spotify (Iphone X user), reverse camera, and Google maps.
I had a look through these options on Allieexpress but my mind boggles:
https://www.aliexpress.com/wholesale...04+touchscreen
Any recommendations most appreciated
Old 05-27-2019, 07:58 AM
  #344
kkkk's Avatar
W204 C63 Estate
Has anyone managed to get a ELM327 OBD2 adapter paired up the unit?
Whenever I press on Bluetooth , it can find the adapter but can't pair to it saying that there is the wrong PIN/passcode. It doesnt even give me the option to enter the code
Old 05-28-2019, 07:25 AM
  #345
spadatony's Avatar
Mercedes A45 AMG
Originally Posted by rashawn.r1020
I AM HAVEING THE SAME EXACT PROBLEM, HAVE YOU FOUND A SOLUTION? I HAVE WIRES IN MY CAR EVERYWHERE AND IM NOT TRYING TO PACK UP AND GIVE UP JUST TO FIND A SOLUTION AND HAVE TO PULL EVERYTHING APART AGAIN.
i had same issue, contacted the seller they sent me a zip file link. I downloaded the file onto my computer then put onto a micro sd card, inserted into micro SD card slot on the back on the right side. Then used a pin in the reset hole on the left side and it reloaded and reset unit to factory settings. All good now
Old 05-31-2019, 12:08 AM
  #346
Atle Lampe's Avatar
W212 2011
Originally Posted by Ungarisch
per the other thread, I've been trying all day to get AndroidAUTO to work but not luck, all I get it the screen below telling me to connect my phone. iPhone's CarPlay worked immediatly. Same thing applys to screen mirroring, which I really dont car much for. Iphone worked, Android did not.
I have tried 3 different versions of the AutoPlayBox APK but they all say the same thing, just different interfaces.
Newest verions of APK
Old 2017 version of APK
I just bougt an android auto USB dongle and installd the apk that followed with it! Works very good
Old 06-07-2019, 07:52 AM
  #347
shan16's Avatar
C250
Did you get 1 from them??
Old 06-07-2019, 07:57 AM
  #348
shan16's Avatar
C250
Can anybody help me by telling me where you guys getting the unit from link would be good
Old 06-07-2019, 08:05 AM
  #349
ChipMIK's Avatar
W204 C180 CDI
I bought mine here....For LHD!
https://www.aliexpress.com/item/Ouch...4b894c4dtYFDY5
Old 06-07-2019, 08:18 AM
  #350
shan16's Avatar
C250
Originally Posted by ChipMIK
Thanks what's LHD means??
Quick Reply: Android 10.25 Screen Unit
