40K mile service
I have the 2014 C300 4Matic Sedan and it will soon be due for 40K mile service.
It will be performed at the dealership, which they are covering the service cost as it was part of the CPO deal.
Does anyone know what type of services will be performed?
And, should I be bringing up any of the issues others might have experience so that the work could be done at the same time under warranty.
Thank you all in advance!
Why would 39K miles instead of the recommended service interval be anything more than wasted money? 39K Miles was what the engineers set for the older transmission so I don’t see why it makes sense to trust their old recommendation for that transmission, but not the new one for the new transmission.
If their intervals lead to transmission failure early that will push up their costs not mine...
I just find that impossible to believe. If that were true buyers would quickly migrate to other brands. Cars today have never been more reliable and people keep them longer than ever before. I read something a while back, I think it was on Autotrader, that said that on average people keep a new car about 6 years and the average age of cars on the road is over 11 years. So if cars were designed to fail after the warranty period there would be a ton of unhappy used car buyers. Engines and transmissions last longer than ever before. It used to be cars that had 100K miles were pretty much done and rusting away.
Manufacturers spend multi millions/billions on R&D and relaibility. Now, is every part on every car as robust as it could be? Not likely, as every car is built to a price point and to appeal to different buyers. And because of weight, cost, emmisions, space, etc. compromises have to be made on every design and manufacturers have to balance all that out. But general quality and overall reliability keep getting better and better all the time. I personally don't think buying a used car that has just come off of warranty as being bad. Think about it; when a car is under warranty, when every squeak, rattle or niggling issue comes up people take it to the dealer to fix. I look at it that by the end of the warranty if that specific car had any issues that came from the factory they have been fully sorted by then and not likley to repeat, so you have a pretty good chance to get a reliable vehicle if everything else checks out.
That is very false, im not saying a car will explode once its out off warranty but the materials they use on new cars and some designs are just deemed to fail well before 200k miles.The more time goes on, the more cars become this way, its the beginning of a sad future for cars, life time fluids are just the start.
They are moving away from modular parts and instead are making everything non serviceable. just look at the new inline 6 mercedes engines that are coming out, water pump, alternator, power steering pump..all non serviceable components that are integrated into the block.. Its cheaper for them to produce that way and harder to service so like I said, no point of fixing it, you ust buy a new one. This alread started with most parts, no one fixes anything anymore, they just replace it.
Cars will be as disposable as phones one day, tell me, do you fix your phone or service it? Once the screen cracks or a component fails and its already 2-3 years old, most people will just go get the latest version instead of fixing it, cars will be the same.
I never had a cell phone fail and if it would I would probably get a new one. I have always gotten a new phone because new ones that came out had so many new or improved features that I wanted to change. And I would guess that most people are like that. And I think that is not uncommon in the car world as well. Some people get a new/used/different car just because they want something different even though their car is perfectly fine. Others, like me had a 10 year old car that still had a lot of useful life left, but had 165K miles and some things were starting to wear out and needing to be replaced. I had the car almost seven years and just wanted something different with additional features/technology that newer cars have. Yes, it is definitely harder for a backyard mechanic to service their cars or to replace parts because of all the electronics and how tightly things are packaged today. On the other hand, there are less people that even want to work on their own cars than there used to be, but then again part of that could be cars are so much more reliable than years ago. Yes, we live in a disposable culture with short attention spans. Now, is that a good or bad thing can certainly be debated. On the other hand, years ago oil needed to be changed every 1,000 miles, tuneups needed to be done every 10,000 and cars rusted through after five years, but you could eassily work on them at home if you wnated. I don't know that I would want to go back to those days.
Only real out of pocket repair I did so far is a thermostat. Other things I will consider wear and tear maintenance items, like spark plugs etc.
I have a 2013 C250 W204 and my manual states that at 40K, the brake fluid should be flushed thoroughly to each brake, the transmisison fluid flushed including replacing the overflow cap inside the pan, transmission filter, magnet, pan bolts and gasket all should be replaced, AND the rear differential should be flushed too.
So if my car states to have this done, I'd suspect yours should be similar. But of course, check your owners manual or the maintenance manual your car came with. if you don't have it, then you can get it from online just google for it.
ALSO... you might want to have a carbon build up cleaning done on your cylinder heads and intake valves as well. 40K miles would have built up a good amount of carbon by now and you'd not want to let that get out of control by waiting until 100,000 miles and then they have to rip apart your engine to manually scrub your parts.
