C250 Coolant hose
I don't know if this is the cause of my occasional misfires but I'm not excluding it.
On my car this hose had perished and had a hole close to the turbo end. Any tear or damage to the hose can draw in unmetered air, potentially resulting in a poor air/fuel mix.
Mercedes only sell the hose as a complete unit (i.e. The entire tube running from the air filter to the turbo), but it's possible to replace just the damaged part with a short length of flexible hose. Otherwise, I think the complete hose assembly costs around $us 180 from memory.
Cheers, David
Had a car wash but they didn't even fill up the gas tank, despite putting 25 miles onto the car.
Follow up inquiry for Cbr944; what is the work around for the push fit if using non original hose? Can a hose clamp be used on either end? The hose connection on the top (see poster's pic) looks straight forward enough, but the connection at the turbo end looks more complicated.
Thank you and all of the respondents that respond to these forums. The money and grief that is saved by your actions is noticed and appreciated.
Mr.Biscuit
Cheers
Good stuff, thanks Cbr944
Mr Biscuit
So in order to repair this hose, one needs to replace the entire intake assembly. I don't have the exact part number but out of warranty it costs about $700 last time I recall.
Alternatively you can try to use this to fix the issue.
If you have a coolant leak or cracked pipe, these should get the job done:
Otherwise you can find the whole assembly online, I believe someone else posted the links above.
https://modalwork.com/products/w204-...-intake-system
Ant
I mean its a permanent solution in fixing that issue and quality is great. You just need to know if you prefer OEM or modified.
Best of Luck and send Modal my regards.
Anthony B.
Anthony B.
I highly recommend it and it looks good too
Ant
leaking from the bottom of the tube i’m pointing at. anyone know where i can get that tube and clamps from? really don’t want to pay to get it fixed at dealer or elsewhere to be honest
"Alternatively you can try to use this to fix the issue.
It was about as simple as it gets to replace. Thanks again bigab24!!
Cheers!!
