Smoke! Every morning! Help identifying a possible leak?
Old Jan 27, 2019 | 10:36 PM
ihaveaquestion's Avatar
2000 C230 Kompressor
Well, video is worth a thousand words so here you go:
It's on the passenger side (US model) of the engine bay. It smokes after the car has been sitting for a while but makes no smoke after the first 15 mins.
I am very bad at identifying parts but I think I see the exhaust pipe underneath a black connector. That's approximately where the smoke comes from. Is there a known issue with this area of engine bay?
My best guess is that there is a leak nearby so when the exhaust gets hot it burns off whatever fluid dripped onto it. I found a wet spot in that area too before it got burned off.
So can someone with knowledge help identify the plausible cause for the smoke? Much appreciated.
Old Jan 28, 2019 | 02:54 AM
xsever's Avatar
2012 C300 4MATIC Sport
Can you remove the plastic engine cover so we/you can see better and exactly where the smoke is coming from? You can search on youtube how to remove the plastic engine cover. It's very easy.
Old Jan 29, 2019 | 01:37 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
It's the centrifuge cover leaking oil onto the exhaust. Also known as the oii and air separator. Replace it along with all the camshaft plugs.
Old Jan 29, 2019 | 08:11 AM
timlippold's Avatar
2008 C300 Sport
Ditto. That was my issue. Feel around oil separator for leaks. Can also shine flashlight around back of engine to look for them around plugs.
Old Jan 29, 2019 | 08:57 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
https://mbworld.org/forums/c-class-w204/654685-diy-centrifuge-cover-oil-separator.html
Old Jan 30, 2019 | 12:20 PM
Thanks much!
I will have a weekend project to do now
Old Jan 30, 2019 | 05:39 PM
So is there one on each side of the engine?
https://photos.app.*******/Yj23qDS98FRJk2Ea8
The first pic is on the driver's side, the other two are on the passenger side. I am about to place an order for parts.
Btw, youtube video shows 6-star nuts but mine are screws. Wonder why.
Is this the right part?
https://www.fcpeuro.com/products/mer...ebi-2720100631
Old Jan 30, 2019 | 07:48 PM
Adi-Benz's Avatar
Yes that's the right part, your pictures don't work btw.
Old Jan 31, 2019 | 08:25 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
My 57K mile C300 has started to give off a mild burning oil smell in that same area since the temps have been in the teens when starting up...a finger swipe around the air/oil separator shows no obvious oil, just a minimal greasy smear but sure that this is the source as in your case. I already changed out the cam plug on that side months ago. Thicker cold oil with a higher initial start pressure I assume is the reason since on warmer days I don't smell anything. I have been too lazy to remove the under cladding to see if there is another leak area.
Old Feb 2, 2019 | 10:03 PM
Honest to god! Anything involved with working so closely to the back firewall is just calling for pain!
First it was the coolant temp sensor and now this! Took me 4 hours to take 4 screws off. Now they are off, I don't want to put them back on because I have stripped a couple of them in the process. If anyone know the correct size of the screw ( not nut) or where to get them please let me know.
A tip for future DIYer - Small adjustable wrench on a T30 screw bit will work wonder...
Peace.
Old Feb 2, 2019 | 11:43 PM
Btw, I notice the new part has more rubber in the middle:
https://photos.app.*******/53EVTNQ7pW5bXQRY6
Is this normal? I find it a little hard to install the new part due to more rubber in the middle...are we supposed to force it in?
Old Feb 3, 2019 | 01:58 AM
MBENZTECH's Avatar
Yes, that is normal. It is a brand new seal. Just center it and push in without damaging anything.
Old Feb 3, 2019 | 09:29 PM
Kelvin Bellrose's Avatar
2007 CLK550 Coupe, 2003 CL600, 2012
Could this part be a source of a vacuum leak as well as spew oil?
