How to remove smoking from headlights and tail lights?
Old Feb 12, 2020 | 11:15 AM
DrivingForce's Avatar
2011 C300 Sport, 6M, Dynamic Handling Pack
I am looking at buying a C300 that has smoking on the headlights and tail lights. Is this difficult to remove? Buying new headlight and taillights would be prohibitively expensive.
Old Feb 12, 2020 | 12:03 PM
Alfadude's Avatar
2012 C300 4Matic
It could be, depending how it was tinted. Search on YouTube. There are plenty of videos about that. Why don't you just ask the dealer/person you are buying it from to remove it back to stock before you will agree to buy it? I would think by having that on there would make it harder to sell the vehicle as that look doesn't appeal to everyone.
Old Feb 12, 2020 | 12:12 PM
Thanks, the car is across the country so I'd be buying sight unseen. However, it appears that used headlights and taillights are plentiful on eBay for not nearly as much as I imagined.
For a 2011 model, if it doesn't have the adaptive headlight package it should be pretty straightforward. Do you know if pre face-lift w204 c300 sports all have incandescent taillights? Or LED?
Old Feb 12, 2020 | 02:48 PM
Alfadude's Avatar
2012 C300 4Matic
I believe the LED tailights started with the facelift models in the 2012 model year. Not 100% sure on that. Maybe someone else could chime in.
Old Feb 12, 2020 | 02:51 PM
May all be a moot point. Somebody has apparently arranged a test drive locally and they won't let me put a deposit on it within 4 hours of that
Old Feb 12, 2020 | 03:57 PM
Alfadude's Avatar
2012 C300 4Matic
Plenty of used C300s out there. I'm sure you can find something closer to home you like soon enough.
Old Feb 12, 2020 | 04:00 PM
This is true, but I'm trying to find the cleanest example of a 2010 or 2011 C300 Sport with a 6 speed manual, and that is proving hard to do!
Old Feb 13, 2020 | 05:29 AM
I ended up putting a deposit on a local car. During the test drive at night I noticed the headlights were extremely dim. Is that because the headlights were also smoked on this other one? I thought this was the stock look for 2011s?
Old Feb 18, 2020 | 01:28 PM
FYI it turns out this is most likely a factory smoke tint. It seemed dim because the headlights were aimed too far downward.
