C220 W204 Right Hand Side cold, LHS warm
The chill feels like external air. I'm thinking blend flaps but here's the puzzle: the rear passenger compartment vents (the ones at the back of the armrest) ALSO have warm air out of the left vent and cold air out of the right vent. (a puzzle because I thought the rear passenger compartment was not able to have left and right temparature adjustment.)
If I press the recirculator button the drivers side windscreen foggs up quickly.
Air con clears the screen and does its usual thing on both sides.
Of course no amount of turning up the heat (on either side) has any effect on the drivers side. Seat heater works fine though Thank God!
(Other things I think are irrelevant but perhaps should be taken into account: Comand screen is blank, functions (except sat nav of course) work fine. I had a leak of a litre of w/washer fluid in the rhs passenger footwell GRR. The car has done 165Kmiles)
interestingly there is no access to the actuator or any of its sensors. So I'm thinking electrical fault, perhaps a bad ground.
W204 Right hand drive. behind the dash. Air box.
The copper wire to the COMAND screen was gnawed and he connector highlighted here is damaged too.
Can anyone tell me what this connector (the little one pointed to by the arrow) is for?
It seems to be a 3 wire (only) connector pretty hard to get to with normal sized hands!
On the driver side LHD the air is very cold, as it should be, when the AC is ON. But on the right side, the air has the outside temperature. When I switch to hot air, both are the same.
There are no faults detected, all flaps, actuators and temp sensors are in parameters.
BTW: The mechanics will try to fool you saying that you cannot replace just the filter, that you have to replace the whole condenser unit. It`s not true. You can. All you need is 14mm inbus socket.
Good luck!
