Coffee in coolant tank om651
Old Feb 21, 2022 | 08:13 AM
dlmrly's Avatar
W204 C250 CDI Sport Sedan
Heya guys,
im having the following symptoms:
- coolant loss, not too fast(half liter in a month)
- coffee on top of coolant in coolant tank
- no overheating, no leaks
- exhaust kinda smells sweet sometimes
- oil clean, no milk or coffee
my mech saying its probably oil coolant, before i go to him on wednesday id be grateful to hear ur opinion, stories.
how much, if, oil coolant repairs cost you?
Old Feb 21, 2022 | 08:19 AM
ALFAitalia's Avatar
Alfa 159
The sweet smell in anti freeze in the exhaust smoke and the coffee look sounds like oil foam in the coolant....just got to trace where its coming from. Head gasket is the obvious place to look..... then oil cooler. Do a leak down test on the cylinders and listen for bubbling then test that the coolant circuit is holding pressure with one of the testers that screws on top of the coolant header tank. Best of luck with it.
Old Feb 21, 2022 | 08:40 AM
dlmrly's Avatar
thing is... there is no smoke, no loss of power whatsoever
Old Feb 21, 2022 | 08:41 AM
dlmrly's Avatar
also seems kinda early for head gasket or crack in the head. Im on 130k kilometers
Old Feb 21, 2022 | 09:16 AM
dlmrly's Avatar
Old Feb 21, 2022 | 10:30 AM
chassis's Avatar
2017 GLE350 4MATIC
Coffee = oil in coolant
Many ways this can happen.
Old Feb 23, 2022 | 08:17 AM
JettaRed's Avatar
Veteran: Army
Quit guessing. Spend $37 for a coolant leak test kit. This will tell you immediately if you have a blown gasket or cracked head.
AmazonSmile: Block Tester BT-500 Combustion Leak Test Kit - Made in USA : Automotive
Old Feb 24, 2022 | 01:06 AM
cvx5832's Avatar
325Ci, 325Cic, C300
Is the turbo coolant cooled on these cars? If so, there’s another vector.
Old Feb 24, 2022 | 05:48 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
I am thinking oil cooler failed.
Old Feb 26, 2022 | 08:00 AM
JettaRed's Avatar
Veteran: Army
Why? It that a common problem? The combustion leak detector will tell with certainty if it's a head gasket or crack in the block. For $40 it's well worth knowing.
Old Feb 26, 2022 | 09:01 AM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by dlmrly
Heya guys,
@dlmrly How are you making out with this?
Old Feb 28, 2022 | 12:58 AM
NZ-Merc's Avatar
Hi,
In my experience where you have oil pressure at say 50 psi inside a oil to water heat exchanger and the water is at say 13 psi and the cooler matrix or o-ring seals between the two fail or leak what happens is oil enters the cooling system when the engine is running this turning the coolant oily and frothy at the radiator cap.
What also happens is when the car is turned off the oil pressure goes to 0 but the water is still at 13 psi for 1/2 hour or so, this is enough to slowly leak small amount of water in to the oil side of the cooler, since it is only small amount of water the heat from restarting and driving the engine is enough to evaporate the water thus no colour change in the oil or water at draining of the engine sump.
There are other possibilities I hear you say..
Okay lets look at the TK tester which is an excellent choice by the way, detects hydrocarbons in the cooing system great but hydro carbons(exhaust gas)/ blown head gasket will not in put raw oil in the cooling system.
Cracked head..
Cracked between the cooling system and internal camshaft area, this will let water in to the oil system - loosing water- small amount will not be see due evaporation, when bad enough the oil will turn white.
Cracked between combustion chamber and water jacket , this will let hydrocarbons in to the cooling system and possibly start up missing on one cylinder -- no oil in to cooling system.
You just have to understand where in the engine pressurised oil and water are close by and the oil cooler is the only place.
Dave
