Car won’t go into gear reveal but doesnt. Move
Old Feb 2, 2023 | 04:28 PM
w204AR's Avatar
w204 c300
C300 w204 won’t go into gear revs but doesnt Move
I want to buy owner say it was leaking. But he’s not car savvy could be engine oil. 140k should I just check fluid level then add if necessary?
Old Feb 2, 2023 | 10:02 PM
spb147's Avatar
W204 2013 C250 Coupe
please elaborate. what fluid is leaking? check what fluid level?
the cars not going to any gear?
Old Feb 2, 2023 | 11:49 PM
cvx5832's Avatar
325Ci, 325Cic, C300
I couldn’t understand anything from that.
Old Feb 3, 2023 | 04:05 PM
w204AR's Avatar
w204 c300
yea lots of typos sorry car runs but doesn’t go into gear so maybe what I want to know is the shifter electronic and would the car not engage on to gear if fluid is low if so is the trans burnt out?
Old Feb 3, 2023 | 04:06 PM
spb147's Avatar
I don’t know much about the shifter but since there isnt a dip stick for the transmission fluid, you wouldnt know your answer until taking it to the mechanic. Any codes on the car?
Old Feb 3, 2023 | 04:07 PM
w204AR's Avatar
w204 c300
no the car won’t go into gear the guys not a mechanic so I’m not sure. How can I put fluid in trans is it from the bottom or can I add some from the top
Old Feb 3, 2023 | 04:09 PM
w204AR's Avatar
w204 c300
no engine light ..can check the codes and see if it has malfunctions?
Are these transmission prone to leaks it has 140k
Old Feb 3, 2023 | 04:16 PM
spb147's Avatar
fill from bottom, theyre not very reliable if theyre not serviced well and in time
Old Feb 3, 2023 | 06:32 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
When you run the shift lever through gears and Park, do the respective lights go ON on the shift console( engine running) ?
Old Feb 4, 2023 | 12:04 PM
w204AR's Avatar
w204 c300
uhm ok I’ll check on that n see yea the engine runs but nothing engages but I’ll double check and see
Old Feb 22, 2023 | 06:10 PM
w204AR's Avatar
w204 c300
it goes into gear but no movement at all no fluid leak and when I put it back in to park it grinds a gear
Old Feb 23, 2023 | 05:43 PM
dahlmer's Avatar
c300 2013
Did you find a solution to this because it just happened with mine, i managed to use slow revs and a slope in the road to get to my destination
Old Mar 5, 2023 | 10:05 AM
w204AR's Avatar
w204 c300
no just changing the transmission now
Old Mar 5, 2023 | 10:39 AM
JettaRed's Avatar
Veteran: Army
Does turning the car off and back on make a difference?
Old Mar 5, 2023 | 06:39 PM
w204AR's Avatar
w204 c300
[QUOTE=JettaRed;8733240]Does turning the car off and back on make a difference?[/QUOTE
I’m buying to fix
Old Mar 5, 2023 | 09:03 PM
JettaRed's Avatar
Veteran: Army
I’m buying to fix
I was really asking the other guy.
Old Mar 6, 2023 | 04:38 AM
dahlmer's Avatar
c300 2013
Took it to a shop and found out it was the driver side shaft that pulled out
