P0344-00 Cam Position Sensor Fault
Old Oct 7, 2023 | 08:29 AM
BobbyC94's Avatar
W204 C250 BlueEfficiency
2011 C250 blue efficiency sport 2.1 diesel, possibly OM651 engine
Yesterday the car decided that when it gets hot to develop some kind of knocking noise. Plugged it in and seem to be getting cam position sensor fault.
my first instinct is to change the sensor and hope for the best. I’ve tried to do some research hoping that others may have encountered something similar before but doesn’t seem to be much around online and if there is it’s a different engine.
hoping that someone may have experienced something similar and can advise if I’m going down the correct route with the sensor or if I need to look elsewhere.
P0344-00
The position sensor of the intake camshaft (cylinder bank 1) has a sporadic malfunction. There Is A General Failure.
Thanks in advance for any advice or feedback.
tried to upload a video but couldn’t so I have a link for it here https://streamable.com/i7bovq
Old Oct 7, 2023 | 09:40 AM
JettaRed's Avatar
Veteran: Army
Put your VIN in at www.lastvin.com to verify your engine type.
If it only happens when the engine gets hot (what does that mean? normal operating temperature?), then there may be some thermal expansion of plastic or metal, and replacing the sensor may be the right thing to do.
Old Oct 7, 2023 | 11:04 AM
JettaRed's Avatar
Veteran: Army
This might be better...
Old Oct 7, 2023 | 11:08 AM
BobbyC94's Avatar
what I meant by when it’s hot is that the noise is pretty much non-existent when the engine is cold. But when it gets to normal operating temperatures then it makes the knocking noises.
Thank you for your advice, I will take a look and see if those videos will guide me in the right direction.
Old Oct 7, 2023 | 11:31 AM
JettaRed's Avatar
Veteran: Army
Again, when at normal operating temperature compared to a "cold" engine, you have thermal expansion, which may be enough to affect the sensor.
Is the DTC current and/or stored (historic)? How soon does the DTC come back after you clear it? Have you looked at the Freeze Frame data to see when the DTC occurs? What scanner are you using?
Old Oct 7, 2023 | 02:03 PM
BobbyC94's Avatar
They’re stored/current, and usual returning within about 5/10 minutes of running.
I’m using snap-on modus reader, I flicked through the engine data but there didn’t seem to be anything standing out
Old Oct 7, 2023 | 03:12 PM
TimC300's Avatar
If it were me I would pull the sensor and inspect it and the wiring/plug. clean everything and put it back. Clear the code and see if it comes back, or the same noise continues. I haven't dealt with this specific issue, but my research leads me to want to clean and inspect everything first before spending money for a new sensor.
Also check the oil level and check the battery voltage/charge just for fun.
Old Oct 7, 2023 | 03:42 PM
BobbyC94's Avatar
Thanks for the advice mate, I’m now having a look at doing that, trying to confirm that I have found the correct sensor at the same time though.
i know you haven’t done this job yourself before but maybe you would be able to confirm this is the intake cam sensor?
Old Oct 7, 2023 | 04:39 PM
TimC300's Avatar
I have no idea about the OM651 engine or diesels in general. The diagram I found does appear to show that sensor you circled over the intake camshaft though, so i would say yes.
Here is a link to the Mercedes OM6510 service manual i just came across. Not alof of info but has some.
https://mymotorlist.com/wp-content/u.../ruk-om651.pdf
Was going to say if you can locate another cam sensor you might try swapping them, then see if the codes/positions change. At least rule out the sensor. From my limited research on this issue im finding most say it is circuit related, and people who replace the sensor end up with the same issue/code.
Old Oct 7, 2023 | 05:06 PM
BobbyC94's Avatar
Thank you for taking a look into this for me and confirming, I took the sensor out and cleaned it up and seems to be running a lot better, I’ve order a replacement for peace of mind also.
i did plug in the code reader with the sensor disconnected and chucked up loads more intake can sensor faults along with the original, so I would say it is the correct one also. And fingers crossed changing the sensor will fix it completely, if not I’ll have to look at the loom.
Old Nov 15, 2024 | 12:49 PM
RaZtar's Avatar
W212 250CDI Bluefficiency 2011
Hi Bobby,
Did you ever get this resolved, sounds to me like it was the cam shaft sensor in your case, however I haven’t been as lucky. Any more input?
Thanks in advance
William
Old Nov 18, 2024 | 02:43 PM
BobbyC94's Avatar
Originally Posted by RaZtar
Hi Bobby,
Thanks in advance
William
I think it did help the initial issue, but unfortunately I believe the chain also jumped a tooth not long after so the car wouldn’t start anymore after that. So ended up selling as spares/repairs
Old Dec 3, 2024 | 05:26 PM
RaZtar's Avatar
That sucks, I am sorry for you.
I've just solved the issue of my own which turned out to be caused by the crankshaft position sensor.
Thanks for your reply Bobby!
