W204 not cranking
We transfer link for the video as well
https://we.tl/t-EogrRkugco
When you put the key in and turn it to "on" do all the lights on the dash come on? Does the steering wheel turn?
You may have an issue with the starter.
Try checking in the front fuse box under the hood. The starter is fuse # 7.
Anyhow I'll edit the thread and add the photos
I did a little searching around and all these faults may come from water getting inside the car and contacting wires/connectors/units.
The front drain ducts are known to get plugged and allow water to back up into the car. The fasteners around the trunk trim get old and brittle/fall apart and allow water in.
You will have to peel back the carpet in the drivers/passenger side floor to check. Go in the trunk and lift up the floor and look under the spare tire for water pooling under it. Even I had a leaky trunk I had to fix.
This is where i would start.
