Rattle from C350 w204
Old Oct 9, 2024 | 07:49 PM
Tysfoe's Avatar
2012 C350
Hello everyone, Im new to Mercedes and have recently purchased a 2012 C350 4matic. I find it has a rattle noise (see video) that sorta changes when the oil cap is open. If anyone could offer any insight on whether its normal or if something needs to be fixed/replaced that would be great! thanks.
Old Oct 10, 2024 | 08:05 PM
JettaRed's Avatar
Veteran: Army
Check if the dipstick is popped up or not. If you unscrew the cap and set it on the hole, does it bounce around of get sucked down?
How many miles are on the car? You have the M276 3.5L NA engine which uses direct injection. The DI High Pressure Fuel Pump is normally a little noisy. But if it gets worse, that means you should change it out.
Old Oct 10, 2024 | 09:06 PM
Tysfoe's Avatar
2012 C350
It has 152k Kilometres, about 95k miles. The dipstick isn't popped up, the oil cap gets sucked down but not excessively.
Old Oct 10, 2024 | 09:29 PM
JettaRed's Avatar
Veteran: Army
I will check my car tomorrow and see if it sounds the same.
Old Oct 10, 2024 | 09:44 PM
Tysfoe's Avatar
2012 C350
Awesome thanks. Also if you don't mind can you check if your car has vacuum on the oil cap? I just wanted to see if that was normal or if there's something wrong with my pcv system. Thanks!!
Old Oct 10, 2024 | 10:31 PM
JettaRed's Avatar
Veteran: Army
I will. Found this as well. Seems you are OK.
Old Oct 11, 2024 | 06:24 PM
JettaRed's Avatar
Veteran: Army
Here's my car running. I do not have the same change in sound that you do, but I do have vacuum on the cap, which is what you want. But there was no change in sound for me other than the vacuum sound when I removed the cap.
Old Oct 11, 2024 | 11:54 PM
Tysfoe's Avatar
2012 C350
Awesome thank you so much! I think ive narrowed it down to something drive belt related. Im going to pull the belt off and run it and see if it still makes the noise.
